Ir para o conteúdo principal
Cordoba C5 Classical Guitar String Replacement
Joana Jimenez
Joana Jimenez e 2 outros colaboradores
Última atualização em June 20, 2024
20 - 30 minutos
Fácil
Guia do aluno destaque
Use this guide to replace the strings of a Cordoba C5 classical guitar. Through regular use, guitar strings will become worn out and/or break, making string replacement a common and necessary repair for the guitar. The strings are essential for the guitar to produce the desired sound, and attaching them properly in the first place can help prevent malfunctions and promote longevity.
There are no special skills or tools required to complete this guide. For ease, complete the guide with the guitar laid on a flat surface.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. Cordoba C5 Classical Guitar String Replacement, String: passo 1, imagem 1 %32 Cordoba C5 Classical Guitar String Replacement, String: passo 1, imagem 2 %32
    • Loosen the guitar string by turning the tuning peg in a counterclockwise direction.
    • The string should be completely loose.
  2. Cordoba C5 Classical Guitar String Replacement: passo 2, imagem 1 %32 Cordoba C5 Classical Guitar String Replacement: passo 2, imagem 2 %32 Cordoba C5 Classical Guitar String Replacement: passo 2, imagem 3 %32
    • Remove the old string from the bridge by undoing the knot and pulling it out from the bridge hole.
  3. Cordoba C5 Classical Guitar String Replacement: passo 3, imagem 1 %32 Cordoba C5 Classical Guitar String Replacement: passo 3, imagem 2 %32 Cordoba C5 Classical Guitar String Replacement: passo 3, imagem 3 %32
    • Remove the other end of the old string from the headstock by undoing the knot on the barrel and pulling it out of the barrel hole.
  4. Cordoba C5 Classical Guitar String Replacement: passo 4, imagem 1 %32 Cordoba C5 Classical Guitar String Replacement: passo 4, imagem 2 %32 Cordoba C5 Classical Guitar String Replacement: passo 4, imagem 3 %32
    • Take your new nylon guitar string and feed one end into the bridge hole.
    • Leave enough string at the base of the body to tie a knot.
    • To tie the knot, hold onto the longer end of the string with your left hand and grab the end of the short string with your right hand. Wrap the end of the short string back around itself two times. The string should resemble a figure-8 pattern.
    • Hold down the knot on the bridge with your fingers and pull the longer end of the string with your left hand to tighten the knot.
  5. Cordoba C5 Classical Guitar String Replacement: passo 5, imagem 1 %32 Cordoba C5 Classical Guitar String Replacement: passo 5, imagem 2 %32 Cordoba C5 Classical Guitar String Replacement: passo 5, imagem 3 %32
    • Feed the other end of the string over the barrel hole. Bring the string over the barrel again and feed it into the barrel hole.
    • This will create a loop that secures the string on the barrel.
  6. Cordoba C5 Classical Guitar String Replacement: passo 6, imagem 1 %32 Cordoba C5 Classical Guitar String Replacement: passo 6, imagem 2 %32 Cordoba C5 Classical Guitar String Replacement: passo 6, imagem 3 %32
    • With your right hand, keep the string tense so that the knot at the bridge does not come undone.
    • Turn the tuning peg clockwise to tighten the string.
  7. Cordoba C5 Classical Guitar String Replacement: passo 7, imagem 1 %32 Cordoba C5 Classical Guitar String Replacement: passo 7, imagem 2 %32 Cordoba C5 Classical Guitar String Replacement: passo 7, imagem 3 %32
    • Check the bridge and headstock to ensure the string is secure.
    • If you have excess string at the headstock, trim it with cutting pliers for a neater look.
Linha de Chegada
Joana Jimenez
Membro desde: 02/20/24
145 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 203
