Ir para o conteúdo principal
Coolpad Defiant Daughterboard Replacement
Elijah Gastin
Elijah Gastin e um outro colaborador
Última atualização em July 29, 2021
5 - 10 minutos
Moderado
Introdução
Ir para o passo 1
Use this guide to replace the daughterboard in your phone.
O que você precisa
Ferramentas
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
  • Phillips #000 Screwdriver
Exibir mais…
  1. Coolpad Defiant Daughterboard Replacement, Back Cover: passo 1, imagem 1 %32 Coolpad Defiant Daughterboard Replacement, Back Cover: passo 1, imagem 2 %32
    • Turn the phone with the back cover facing towards you.
    • Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
    • The plastic case and inner components can break if not pulled carefully, so pull cautiously.
  2. Coolpad Defiant Daughterboard Replacement: passo 2, imagem 1 %32
    • Remove the back cover from your device.
  3. Coolpad Defiant Daughterboard Replacement, Battery: passo 3, imagem 1 %32
    • Find the gap on the bottom of the battery.
    • With a tool or with your hands, pull the battery upward and set it aside safely.
    • Remember to return the battery once you are done, safely placing it in the correct position or as how you first saw it.
    • Be careful with old or damaged batteries and dispose of it appropriately
  4. Coolpad Defiant Daughterboard Replacement, Daughterboard: passo 4, imagem 1 %32 Coolpad Defiant Daughterboard Replacement, Daughterboard: passo 4, imagem 2 %32
    • Remove all fifteen screws using the Phillips #000 screwdriver.
    • Remove the back panel after all screws are removed.
  5. Coolpad Defiant Daughterboard Replacement: passo 5, imagem 1 %32 Coolpad Defiant Daughterboard Replacement: passo 5, imagem 2 %32 Coolpad Defiant Daughterboard Replacement: passo 5, imagem 3 %32
    • Disconnect the metal cable using the plastic spudger.
    • The remove the glued down speaker from the backing.
    • Disconnect the little black wire from lower logic board.
  6. Coolpad Defiant Daughterboard Replacement: passo 6, imagem 1 %32
    • Using the plastic spudger remove the lower logic board because the only thing that is holding it down is glue.
Conclusão
Elijah Gastin
Membro desde: 09/21/18
100 Reputação
Autoria de 1 guia
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Ao todo: 490
