Ir para o conteúdo principal
Conventional Electric Stovetop Plug-in Burner Replacement
Chloe Martin
Chloe Martin e um outro colaborador
Última atualização em December 27, 2018
Nenhuma estimativa
Muito fácil
Guia colaborativo
Faltando detalhes
This guide will tell you how to exchange an old detective plug in burner on a conventional electric stovetop. You should disconnect your stove before you begin to replacement process. You should also have purchased a replacement for your burner in the correct size.
O que você precisa
  1. Conventional Electric Stovetop Plug-in Burner Replacement, Plug-in Burner: passo 1, imagem 1 %32
    • Check that the burner is turned off or your stove is unplugged.
  2. Conventional Electric Stovetop Plug-in Burner Replacement: passo 2, imagem 1 %32
    • Detach the stove burner by gently lifting it up (you can use a flat head screwdriver to lift the burner if it is stuck).
  3. Conventional Electric Stovetop Plug-in Burner Replacement: passo 3, imagem 1 %32 Conventional Electric Stovetop Plug-in Burner Replacement: passo 3, imagem 2 %32
    • Gently pull the burner from the plug in (straight back towards you). The plug in is better depicted in the second picture of this step.
  4. Conventional Electric Stovetop Plug-in Burner Replacement: passo 4, imagem 1 %32
    • Dispose of your old burner and take your new burner out of its packaging. It is ready to attach.
  5. Conventional Electric Stovetop Plug-in Burner Replacement: passo 5, imagem 1 %32
    • Gently insert the burner into the plug in, you should feel it click into place.
  6. Conventional Electric Stovetop Plug-in Burner Replacement: passo 6, imagem 1 %32
    • Gently set the burner back onto the stovetop.
  7. Conventional Electric Stovetop Plug-in Burner Replacement: passo 7, imagem 1 %32
    • Now the stove is ready to be plugged back into the wall (if you detached it) and the burner is ready to be tested to see if it is working.
Conclusão
Uma outra pessoa concluiu este guia.
Chloe Martin
Membro desde: 10/29/18
172 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 22
Duração total: 2,523
