Ir para o conteúdo principal
Container Store Office Chair 10052635 Arm Repair
Allyson Amegashie
Allyson Amegashie e 2 outros colaboradores
Última atualização em December 30, 2021
10 - 20 minutos
Fácil
The product name and model number is the Container Store Big Flat Bungee Office Chair with Arms model number 10052635. This guide will teach you how to repair a loose arm on a swivel chair like the one in this guide. Step 4 requires you to check if the hole for the screw has become enlarged. If it has a larger hex screw may be needed.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. Container Store Office Chair 10052635 Arm Repair, Container Store Office Chair 10052635 Arm Repair: passo 1, imagem 1 %32 Container Store Office Chair 10052635 Arm Repair, Container Store Office Chair 10052635 Arm Repair: passo 1, imagem 2 %32
    • Remove the screw caps on both sides of the arm of the chair.
  2. Container Store Office Chair 10052635 Arm Repair: passo 2, imagem 1 %32
    • Place the screw caps to the side.
  3. Container Store Office Chair 10052635 Arm Repair: passo 3, imagem 1 %32 Container Store Office Chair 10052635 Arm Repair: passo 3, imagem 2 %32
    • Wiggle the arms of the chair to determine which sides may need tightening.
  4. Container Store Office Chair 10052635 Arm Repair: passo 4, imagem 1 %32 Container Store Office Chair 10052635 Arm Repair: passo 4, imagem 2 %32 Container Store Office Chair 10052635 Arm Repair: passo 4, imagem 3 %32
    • Use an Allen wrench to remove the arm to make sure the plastic hole for the screw has not become enlarged.
  5. Container Store Office Chair 10052635 Arm Repair: passo 5, imagem 1 %32 Container Store Office Chair 10052635 Arm Repair: passo 5, imagem 2 %32 Container Store Office Chair 10052635 Arm Repair: passo 5, imagem 3 %32
    • Use an Allen wrench to tighten the screw.
  6. Container Store Office Chair 10052635 Arm Repair: passo 6, imagem 1 %32 Container Store Office Chair 10052635 Arm Repair: passo 6, imagem 2 %32
    • Get the screw caps and place them back in the arms of the chair.
Linha de Chegada
Allyson Amegashie
Membro desde: 09/30/21
133 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 663
