Ir para o conteúdo principal
Compaq Mini 110 Hard Drive Replacement
alea
alea e 7 outros colaboradores
Última atualização em June 10, 2022
1 minuto
Fácil
Faltando Passos
Melhor Introdução
O que você precisa
Ferramentas
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
  • Phillips #1 Screwdriver
Exibir mais…
  1. Compaq Mini 110 Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Compaq Mini 110 Hard Drive Replacement, Battery: passo 1, imagem 2 %32
    • Locate the battery and the battery tabs on the bottom of the Compaq Mini.
  2. Compaq Mini 110 Hard Drive Replacement: passo 2, imagem 1 %32 Compaq Mini 110 Hard Drive Replacement: passo 2, imagem 2 %32 Compaq Mini 110 Hard Drive Replacement: passo 2, imagem 3 %32
    • Push both tabs inward simultaneously and slide the battery out.
  3. Compaq Mini 110 Hard Drive Replacement, RAM: passo 3, imagem 1 %32 Compaq Mini 110 Hard Drive Replacement, RAM: passo 3, imagem 2 %32
    • Use a Philips #0 screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
  4. Compaq Mini 110 Hard Drive Replacement: passo 4, imagem 1 %32
    • Push out the side tabs simultaneously and pull out the old RAM module.
    • When inserting a new RAM stick, be sure to evenly insert the gold pins in the same orientation that the old module was removed. While sliding the module in, press the side tabs in place.
  5. Compaq Mini 110 Hard Drive Replacement, Keyboard: passo 5, imagem 1 %32 Compaq Mini 110 Hard Drive Replacement, Keyboard: passo 5, imagem 2 %32
    • Remove the rubber pads located on the corners of your Compaq Mini.
    • There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
  6. Compaq Mini 110 Hard Drive Replacement: passo 6, imagem 1 %32 Compaq Mini 110 Hard Drive Replacement: passo 6, imagem 2 %32
    • Unscrew all the corner screws. There are four total, one under each rubber pad.
  7. Compaq Mini 110 Hard Drive Replacement: passo 7, imagem 1 %32 Compaq Mini 110 Hard Drive Replacement: passo 7, imagem 2 %32
    • Unscrew the screw for the bottom case located in the RAM compartment.
    Falta um passo, pois nos modelos COMPAQ MINI 110, existe um parafuso que segura o teclado, que se encontra bem escondido dentro da cavidade que encaixa a bateria.
    Amilcar Correia - Responder
  8. Compaq Mini 110 Hard Drive Replacement: passo 8, imagem 1 %32 Compaq Mini 110 Hard Drive Replacement: passo 8, imagem 2 %32
    • Remove the three screws in the silver tabs at the back of the keyboard.
    • These are located at the back of the base under the screen.
    • Lift the keyboard away from the laptop.
    3 screws in red circles are actually on metal tabs in the battery compartment, 1 deeper than the other 2. There is a keyboard symbol for each of the 3 screws.
    Step 8B: Lift out keyboard by pushing upwards on the 2 accessible metal tabs. This is the most difficult step. Lack of Quality Control during assembly may prevent the kevboard from lifting out without breaking!!
    John - Responder
    This step may be performed after battery removal. Use care when removing ribbon cable: the white clips holding the black plastic "keeper" are fragile. Reassembly possible without white clips; however, jostling may cause the ribbon to come free.
    Jason L - Responder
  9. Compaq Mini 110 Hard Drive Replacement, Hard Drive: passo 9, imagem 1 %32
    • Remove the three screws holding the panel in place.
  10. Compaq Mini 110 Hard Drive Replacement: passo 10, imagem 1 %32 Compaq Mini 110 Hard Drive Replacement: passo 10, imagem 2 %32
    • Pull up on the tab to remove the hard drive.
Conclusão
16 outras pessoas executaram este guia.
alea
Membro desde: 10/06/10
1.417 Reputação
Autoria de 14 guias
Equipe
Cal Poly, Team 22-2, Maness Fall 2010 Membro de Cal Poly, Team 22-2, Maness Fall 2010
CPSU-MANESS-F10S22G2
6 Membros
Autoria de 20 guias
2 comentários
still cannot remove back of my compacq mini. i have taken all screws out as told but back refuses to part.
madudman - Responder
still cannot remove back of my compact after removing all screws. are ther any more hidden clips ? mike
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 60
Ao todo: 39,173
