Ir para o conteúdo principal
Compact Fluorescent Lightbulb CFL Lightbulb Replacement
WiseGeek
WiseGeek e 5 outros colaboradores
Última atualização em August 16, 2019
5 minutos
Muito fácil
Guia colaborativo
Introdução
Ir para o passo 1
The CFL lightbulb has taken over in today's suburban home. Using less than 30 watts to power it and having the same light output as a standard 100 watt incandescent bulb, the CFL is certainly a "bright idea".
  1. Compact Fluorescent Lightbulb CFL Lightbulb Replacement, CFL Lightbulb: passo 1, imagem 1 %32 Compact Fluorescent Lightbulb CFL Lightbulb Replacement, CFL Lightbulb: passo 1, imagem 2 %32
    • Locate the bad bulb and remove it from the socket. This is achieved by grabbing the bulb lightly and rotating counter-clockwise.
    • The bulb may be hot. If so, use gloves, or wait for it to cool.
  2. Compact Fluorescent Lightbulb CFL Lightbulb Replacement: passo 2, imagem 1 %32
    • Procure a new lightbulb, either from a hardware store, or wherever it is you keep new ones.
    • Install the new lightbulb into the socket, this time rotating clockwise.
    • Be sure the power to the socket is turned off before you preform this step. Failure to do so my cause injury.
  3. Compact Fluorescent Lightbulb CFL Lightbulb Replacement: passo 3, imagem 1 %32
    • Turn the power on to the light socket by means of a switch or knob.
    • Congratulations! You have successfully changed a lightbulb! Reward your efforts by getting a cold beverage of your choice.
Linha de Chegada
12 outras pessoas executaram este guia.
WiseGeek
Membro desde: 04/04/11
1.364 Reputação
Autoria de 2 guias
1Comentário do guia
You shouldn't unscrew/screw CFL Bulb from its tube because there is a very small risk that it will break (Especially if it has the tubular shape (2U, 3U and 4U)). Try to unscrew/screwing it from its plastic base.
Jokid - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 24
Ao todo: 8,213
