Ir para o conteúdo principal
How to Hook up Front Panel Connectors to an ATX Motherboard
Nathan Carini
Nathan Carini e 2 outros colaboradores
Última atualização em May 27, 2024
15 - 30 minutos
Fácil
Precisa de mais images
Introdução
Ir para o passo 1
When it comes to building a computer it takes lots of time and determination to put everything together. By splitting up a big project into smaller pieces, the project becomes much less daunting. In this guide, I will detail how to hook up your front panel connectors from your computer chassis to your ATX Motherboard with ASUS Z490 Wi-Fi (ASIN: B086QSD3M4). In other words, I will teach you how to get your front panel inputs/outputs (Reset, Power On, LED Power light) to actually work.
When building a computer it is necessary to ensure that your motherboard is compatible with all other components including the computer chassis.
WARNING:
  • Do not work on a motherboard on the carpet. Static electricity can fry the motherboard.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. How to Hook up Front Panel Connectors to an ATX Motherboard, How to Hook up Front Panel Connectors to an ATX Motherboard: passo 1, imagem 1 %32 How to Hook up Front Panel Connectors to an ATX Motherboard, How to Hook up Front Panel Connectors to an ATX Motherboard: passo 1, imagem 2 %32 How to Hook up Front Panel Connectors to an ATX Motherboard, How to Hook up Front Panel Connectors to an ATX Motherboard: passo 1, imagem 3 %32
    • Lay your PC on its side and unscrew the side panel thumb screws. (Open your PC case)
    • For some computer cases you may need a screw driver to remove actual screws.
  2. How to Hook up Front Panel Connectors to an ATX Motherboard: passo 2, imagem 1 %32 How to Hook up Front Panel Connectors to an ATX Motherboard: passo 2, imagem 2 %32
    • Once the screws are removed lift off the side panel to expose the motherboard and internal cables.
    • Locate where the front panel pins are.
  3. How to Hook up Front Panel Connectors to an ATX Motherboard: passo 3, imagem 1 %32 How to Hook up Front Panel Connectors to an ATX Motherboard: passo 3, imagem 2 %32 How to Hook up Front Panel Connectors to an ATX Motherboard: passo 3, imagem 3 %32
    • Plug the cable marked Reset SW into the motherboard. This will allow your reset button to actually work.
  4. How to Hook up Front Panel Connectors to an ATX Motherboard: passo 4, imagem 1 %32 How to Hook up Front Panel Connectors to an ATX Motherboard: passo 4, imagem 2 %32 How to Hook up Front Panel Connectors to an ATX Motherboard: passo 4, imagem 3 %32
    • Plug the Power SW cable in above the Reset SW on the motherboard. This will allow you to turn on your computer with the power button on the front of your PC case.
  5. How to Hook up Front Panel Connectors to an ATX Motherboard: passo 5, imagem 1 %32 How to Hook up Front Panel Connectors to an ATX Motherboard: passo 5, imagem 2 %32 How to Hook up Front Panel Connectors to an ATX Motherboard: passo 5, imagem 3 %32
    • Plug the Power Led + into the top left prong. Positive goes on the left prong.
  6. How to Hook up Front Panel Connectors to an ATX Motherboard: passo 6, imagem 1 %32 How to Hook up Front Panel Connectors to an ATX Motherboard: passo 6, imagem 2 %32 How to Hook up Front Panel Connectors to an ATX Motherboard: passo 6, imagem 3 %32
    • Connect the Power Led - cable to the prong on the right.
    • This is the final cable structure.
  7. How to Hook up Front Panel Connectors to an ATX Motherboard: passo 7, imagem 1 %32
    • Power LED
    • Power Switch
    • Reset Switch
Conclusão
To reassemble your device, follow the instructions, steps 1 and 2, in reverse order.
9 outras pessoas executaram este guia.
Nathan Carini
Membro desde: 03/26/21
315 Reputação
Autoria de 1 guia
Equipe
2 comentários
Petite précision :
Les broches sur lesquels il faut brancher les connecteurs des différents éléments du boitier sont indiquées dans la notice de la carte mère (button power, LEDs, etc.). L’emplacement et l’ordre de branchement des différents éléments du boitier est susceptible de varier selon le modèle de la carte mère.
Cela concerne aussi le buzzer si vous en avez un.
Brendan - Responder
Bonjour Tout le monde*
Je suis d'accord avec vous , mais dans quel sens mettre sur le boitier de démarrage vous avez power reset led 2 prise usb , quand j'ai enlevé du boitier je n'ai marquer les metttre ou
Je vous remercie d'avance.
KIEFFER RENE - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 91
Últimos 7 dias: 572
Últimos 30 dias: 2,851
Ao todo: 111,255
