Ir para o conteúdo principal
Classic Ripstik Caster Board Torsion Bar Replacement
Mariana Ayapantecatl
Mariana Ayapantecatl e 2 outros colaboradores
Última atualização em December 26, 2023
30 - 45 minutos
Fácil
Guia do aluno destaque
There is nothing quite like the feeling of riding a Razor RipStik Classic Board; however, if your Razor RipStik has lost its ability to twist seamlessly, you most likely have a worn-out torsion bar, which requires replacement. With this guide, you will be able to replace the torsion bar on a RipStik Classic Caster Board.
A functional torsion bar provides the resistance needed for the RipStik to twist along with the rider’s hips. When you have been riding for quite some time, eventually, the torsion bar will become tight making it difficult to ride. A worn-out torsion bar will make it difficult for the plates to twist oppositely. If you notice that your RipStik is not twisting like usual, consider checking for rust. If you continue to notice the RipStik is not twisting as seamlessly as normal, you should replace the torsion bar.
A faulty torsion bar can cause an injury. If your torsion bar has rust, take appropriate precautions.
All it takes is a couple of minutes and minimal skills to ensure the safety and enjoyment of your next ride.
  1. Classic Ripstik Caster Board Torsion Bar Replacement, Torsion Bar: passo 1, imagem 1 %32 Classic Ripstik Caster Board Torsion Bar Replacement, Torsion Bar: passo 1, imagem 2 %32 Classic Ripstik Caster Board Torsion Bar Replacement, Torsion Bar: passo 1, imagem 3 %32
    • Use a 5 mm Allen Wrench to remove the two bolts attaching the front and back deck platforms to the torsion bar.
    • If your bolts have rusted, we recommend using WD-40 Specialist: Rust Remover Soak to remove rust from the bolts.
  2. Classic Ripstik Caster Board Torsion Bar Replacement: passo 2, imagem 1 %32 Classic Ripstik Caster Board Torsion Bar Replacement: passo 2, imagem 2 %32 Classic Ripstik Caster Board Torsion Bar Replacement: passo 2, imagem 3 %32
    • Pull the torsion bar and torsion ball shell from each deck platform to separate them.
    • Slide the damaged torsion bar out of the torsion bar shell.
  3. Classic Ripstik Caster Board Torsion Bar Replacement: passo 3, imagem 1 %32 Classic Ripstik Caster Board Torsion Bar Replacement: passo 3, imagem 2 %32
    • Clean the torsion bar shell and inner deck platforms of dirt and rust with soap and damp towel.
    • We recommend wearing gloves as you might be dealing with rust.
    • WD-40 Specialist: Rust Remover Soak may be utilized for excessive rust.
  4. Classic Ripstik Caster Board Torsion Bar Replacement: passo 4, imagem 1 %32 Classic Ripstik Caster Board Torsion Bar Replacement: passo 4, imagem 2 %32
    • Apply white lithium grease to the inside of the deck platforms and torsion bar shell.
    • Avoid contact with eyes and skin when utilizing white lithium grease.
    • If gloves are unavailable, then you can substitute with a paper towel or popsicle stick to spread grease.
  5. Classic Ripstik Caster Board Torsion Bar Replacement: passo 5, imagem 1 %32 Classic Ripstik Caster Board Torsion Bar Replacement: passo 5, imagem 2 %32 Classic Ripstik Caster Board Torsion Bar Replacement: passo 5, imagem 3 %32
    • Insert the new torsion bar into the torsion bar shell.
    • Align the threaded holes into the original position with the bolt holes.
    • Remember to face the flat side of the thread hole upwards toward the ceiling.
  6. Classic Ripstik Caster Board Torsion Bar Replacement: passo 6, imagem 1 %32 Classic Ripstik Caster Board Torsion Bar Replacement: passo 6, imagem 2 %32
    • Reattach the two 5 mm bolts connecting the torsion bar and deck platforms with the Allen wrench.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 348
