Ir para o conteúdo principal
Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement
Sam Omiotek
Sam Omiotek e um outro colaborador
Última atualização em November 4, 2020
30 minutos - 1 hora
Moderado
Em progresso
  1. Cuidado: os passos de 1 a 4 são provenientes de um guia marcado como em andamento.
    Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement, Safety precautions: passo 1, imagem 1 %32 Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement, Safety precautions: passo 1, imagem 2 %32
    • Make sure the engine is off and cool to the touch before you proceed.
  2. Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: passo 2, imagem 1 %32
    • Place wheel chocks against the roller and rear wheel to prevent the machine from moving.
  3. Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: passo 3, imagem 1 %32 Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: passo 3, imagem 2 %32
    • Flip the gas shutoff switch next to the motor to the left into the off position.
  4. Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: passo 4, imagem 1 %32 Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: passo 4, imagem 2 %32
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  5. Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement, Remove the eccentric arms: passo 5, imagem 1 %32
    • Use a 3/4 inch socket to remove the two bolts on the eccentric arm.
    • You may need to use a 3/4 inch wrench in combination with the socket wrench to hold the nuts in place.
    • During reassembly, apply threadlocker to the bolt securing the eccentric arm to the blade arm.
  6. Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: passo 6, imagem 1 %32 Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: passo 6, imagem 2 %32
    • Remove the plastic washer from between the eccentric arm and the blade arm.
  7. Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: passo 7, imagem 1 %32
    • Lift the eccentric arm away from the blade arm.
  8. Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: passo 8, imagem 1 %32 Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: passo 8, imagem 2 %32
    • Remove the steel washer from the eccentric shaft.
  9. Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: passo 9, imagem 1 %32
    • Remove the plastic washer from the eccentric shaft.
  10. Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: passo 10, imagem 1 %32 Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: passo 10, imagem 2 %32
    • Remove the eccentric arm and plastic washer from the eccentric shaft.
    • Repeat steps 5–10 for the other eccentric arm.
    • During reassembly, use a grease gun to add grease to the bearings through the two Zerk fittings on each eccentric arm.
Conclusão
3 outras pessoas executaram este guia.
Sam Omiotek
Membro desde: 02/25/19
84.587 Reputação
Autoria de 290 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 37
Ao todo: 1,926
