Chef's Choice M115 Power Cord Replacement
Introdução
Vá para o passo 1Power cords on appliances such as this can get damaged easily. Instead of throwing it out, consider replacing the cord. As with any other electrical device, a damaged power cord can cause a fire or injury, so this guide can assist in reducing that risk.
O que você precisa
Remove the two rubber feet on the motor side of the device.
Remove the five Phillips screws from the bottom of the case.
To reassemble your device, follow these instructions in reverse order. Take care to ensure the power connections are connected back to their original location.
Uma outra pessoa concluiu este guia.
