Ir para o conteúdo principal
Charge 3 Battery Replacement
Supper Simon
Supper Simon e um outro colaborador
Última atualização em January 25, 2024
30 minutos - 1 hora
Moderado
Pontos lista!
Guia colaborativo
Melhor Introdução
Introdução
Ir para o passo 1
This repair helps fix bad battery life which could cause the device to reboot at random
O que você precisa
Peças
Ferramentas
Exibir mais…
A iFixit ganha comissão quando você compra por estes links.
  1. Charge 3 Battery Replacement, Battery: passo 1, imagem 1 %32 Charge 3 Battery Replacement, Battery: passo 1, imagem 2 %32 Charge 3 Battery Replacement, Battery: passo 1, imagem 3 %32
    • It is recommended to let the battery discharge before starting. It's a precaution to prevent the battery from lighting on fire if punctured.
    • Remove both T2 screws
    • Slide off the plastic piece by lifting out and then up
    • Slide plastic and spring assembly off the rail
    • Watch out for the spring on in the band release
  2. Charge 3 Battery Replacement: passo 2, imagem 1 %32 Charge 3 Battery Replacement: passo 2, imagem 2 %32 Charge 3 Battery Replacement: passo 2, imagem 3 %32
    • Heat the glass screen with a blowdryer to soften the adhesives
    • Start the next step on the opposite side of the Fitbit wording below the glass. This is due to the display cables being located there
    • Insert a razor blade between the glass and the body
    • Keep going around the rim of the display until loose
  3. Charge 3 Battery Replacement: passo 3, imagem 1 %32
    • This is how close those cables get to the edge underneath the Fitbit wording so be careful
  4. Charge 3 Battery Replacement: passo 4, imagem 1 %32 Charge 3 Battery Replacement: passo 4, imagem 2 %32 Charge 3 Battery Replacement: passo 4, imagem 3 %32
    • Lift the display then battery up gently
    • The battery is attached with a little bit of adhesive so lift it gently
    • Remove battery connector
  5. Charge 3 Battery Replacement: passo 5, imagem 1 %32 Charge 3 Battery Replacement: passo 5, imagem 2 %32
    • Connect new battery connector
    • Peel the plastic layer off the adhesive backing
    • Put the battery back in place
  6. Charge 3 Battery Replacement: passo 6, imagem 1 %32
    • Add a thin layer of E-6000 glue around the casing
    • Make sure to cover the entire surface that makes contact with the screen to keep the device waterproof
  7. Charge 3 Battery Replacement: passo 7, imagem 1 %32 Charge 3 Battery Replacement: passo 7, imagem 2 %32
    • Flip down the screen and remove any extra glue that squeezes out
    • Take a rubber band and wrap it around the device, this will ensure the display stays in place until the glue cures
    • With the rubber bands on go to step 1 and reverse the steps to reinstall the band release
    • The glue will take between 24 and 72 hours to fully cure
    • When the glue is fully cured remove the rubber bands
    • After all is done you will need to calibrate the battery to do this charge it to 100% then leave it charging for an extra 2 hours use the device until it dies of low power and finally charge it to 100% and it should be good to go
    • And walla you now have a repaired Fitbit Charge 3
Conclusão
Thanks to ShellingRook27's Original Dissasembly I Was Able to Make this Guide And Bring a new life to my old device.
Supper Simon
Membro desde: 03/18/23
464 Reputação
Autoria de 2 guias
4Comentários do guia
Fantastic - thanks for sharing!
K80 - Responder
No problem anything to make the world a more fixable place
Supper Simon -
Hi! My fitbit charge 4 is taken apart now but now that I've lifted the battery what I see is completely different from what's shown in the photo. If I haven't already destroyed my Fitbit, how about a version for the Fitbit 4? Or a video would be even better. In the meantime, I'm stuck. I bought the battery from you.
Regi
Regina Merwin - Responder
I don't have a charge 4 so I'm only going off the internet here, but you can follow some of the steps here to replace the battery https://www.youtube.com/watch?v=2C1DiVXj... and if you need any further guidance please let me know
Supper Simon -
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 30
Últimos 30 dias: 106
Ao todo: 2,260
