Charge 3 Battery Replacement
Introdução
Vá para o passo 1This repair helps fix bad battery life which could cause the device to reboot at random
O que você precisa
Peças
Ferramentas
Exibir mais…
Remove both T2 screws
Slide off the plastic piece by lifting out and then up
Slide plastic and spring assembly off the rail
Thanks to ShellingRook27's Original Dissasembly I Was Able to Make this Guide And Bring a new life to my old device.
4 comentários
No problem anything to make the world a more fixable place
Hi! My fitbit charge 4 is taken apart now but now that I've lifted the battery what I see is completely different from what's shown in the photo. If I haven't already destroyed my Fitbit, how about a version for the Fitbit 4? Or a video would be even better. In the meantime, I'm stuck. I bought the battery from you.
Regi
I don't have a charge 4 so I'm only going off the internet here, but you can follow some of the steps here to replace the battery https://www.youtube.com/watch?v=2C1DiVXj... and if you need any further guidance please let me know
