Ir para o conteúdo principal
Casio WK-220 Black Keys Replacement
Alexa
Alexa e 3 outros colaboradores
Última atualização em April 11, 2017
Nenhuma estimativa
Moderada
This guide will teach you how to remove, clean, and replace the black keys of the keyboard.
O que você precisa
Peças
Ferramentas
Exibir mais…
A iFixit ganha comissão quando você compra por estes links.
  1. Casio WK-220 Black Keys Replacement, White Keys: passo 1, imagem 1 %32 Casio WK-220 Black Keys Replacement, White Keys: passo 1, imagem 2 %32
    • Place device face-down
    • Remove 23 16mm screws with Phillips #2 screwdriver
  2. Casio WK-220 Black Keys Replacement: passo 2, imagem 1 %32 Casio WK-220 Black Keys Replacement: passo 2, imagem 2 %32
    • Pry up long back panels with plastic opening tool
    • Remove panels
  3. Casio WK-220 Black Keys Replacement: passo 3, imagem 1 %32
    • Turn device around so keys are face-up
  4. Casio WK-220 Black Keys Replacement: passo 4, imagem 1 %32 Casio WK-220 Black Keys Replacement: passo 4, imagem 2 %32
    • Pull back panel away from keyboard and out of the way
  5. Casio WK-220 Black Keys Replacement: passo 5, imagem 1 %32 Casio WK-220 Black Keys Replacement: passo 5, imagem 2 %32 Casio WK-220 Black Keys Replacement: passo 5, imagem 3 %32
    • Remove speaker(s) if necessary to access desired key section(s)
    • Use Phillips #2 screwdriver to remove two 16 mm screws (circled in red)
    • Pop wires out of plastic holders so speaker can be moved out of the way
    • Move speaker out of the way
    • See speaker replacement guide for more detail on these steps
  6. Casio WK-220 Black Keys Replacement: passo 6, imagem 1 %32 Casio WK-220 Black Keys Replacement: passo 6, imagem 2 %32 Casio WK-220 Black Keys Replacement: passo 6, imagem 3 %32
    • Remove 4 18 mm screws (circled in red) from desired key section using Philips #1 screwdriver
    • Gently push white keys away from screws and pull up to remove from keyboard. Repeat this with the black keys
    • Reassemble with new/cleaned keys
  7. Casio WK-220 Black Keys Replacement, Black Keys: passo 7, imagem 1 %32 Casio WK-220 Black Keys Replacement, Black Keys: passo 7, imagem 2 %32
    • Remove second white section covering desired black section
    • Remove screws using Phillips #1 screwdriver
    • Push keys away from screws and pull up
  8. Casio WK-220 Black Keys Replacement: passo 8, imagem 1 %32 Casio WK-220 Black Keys Replacement: passo 8, imagem 2 %32 Casio WK-220 Black Keys Replacement: passo 8, imagem 3 %32
    • Use plastic opening tool to pry up black key section
    • Remove black key section
    • Reassemble with new/clean black key section
Conclusão
Alexa
Membro desde: 01/24/17
687 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 10-2, Banghart Winter 2017 Membro de Cal Poly, Team 10-2, Banghart Winter 2017
CPSU-BANGHART-W17S10G2
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 827
