Ir para o conteúdo principal
Casio CZ-1000 Barrel Plug Replacement
Jace Alexander
Jace Alexander e 2 outros colaboradores
Última atualização em January 2, 2025
10 - 20 minutos
Moderada
Use this guide to replace the barrel plug on your Casio CZ-1000 synthesizer. The barrel plug is an essential component that connects your device to its power source. Over time, it may wear out, become damaged, or lose its connection, causing power issues. This step-by-step guide will walk you through the replacement process, ensuring your synthesizer can function properly again. You’ll need to know how to use basic tools like a soldering iron and a lint-free cloth, as well as some patience if you are new to soldering.
O que você precisa
Ferramentas
Exibir mais…
A iFixit ganha comissão quando você compra por estes links.
  1. Casio CZ-1000 Barrel Plug Replacement, Backplate: passo 1, imagem 1 %32 Casio CZ-1000 Barrel Plug Replacement, Backplate: passo 1, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the eleven 7.5 mm screws securing the back plate.
  2. Casio CZ-1000 Barrel Plug Replacement: passo 2, imagem 1 %32 Casio CZ-1000 Barrel Plug Replacement: passo 2, imagem 2 %32 Casio CZ-1000 Barrel Plug Replacement: passo 2, imagem 3 %32
    • Using a Phillips #1 screwdriver, remove all 14 5.5 mm screws from the two motherboards.
    • These screws secure the motherboards to the keyboard assembly and the dial on the right side.
  3. Casio CZ-1000 Barrel Plug Replacement: passo 3, imagem 1 %32 Casio CZ-1000 Barrel Plug Replacement: passo 3, imagem 2 %32 Casio CZ-1000 Barrel Plug Replacement: passo 3, imagem 3 %32
    • Carefully cut the zip tie located in the right-hand corner using a pair of scissors or wire cutters.
    • Be sure to avoid cutting any nearby wires or components.
    • Gently slide all the plugs out of their sockets.
    • This will prevent them from catching on anything or damaging the connectors as you lift.
  4. Casio CZ-1000 Barrel Plug Replacement, Barrel Plug: passo 4, imagem 1 %32
    • Clean the area around the barrel plug on the board using a lint-free cloth or a paper towel to remove dust or debris.
    • This ensures a clean working surface and better visibility of the solder joints.
  5. Casio CZ-1000 Barrel Plug Replacement: passo 5, imagem 1 %32 Casio CZ-1000 Barrel Plug Replacement: passo 5, imagem 2 %32
    • Hold the soldering iron against the solder joint for a few seconds to melt it, then gently pull the barrel plug out while the solder is liquid.
Conclusão
Jace Alexander
Membro desde: 10/24/24
181 Reputação
Autoria de 2 guias
Equipe
Cuesta, Team 60-3, Krynen Fall 2024 Membro de Cuesta, Team 60-3, Krynen Fall 2024
CUESTA-KRYNEN-F24S60G3
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 42
