Ir para o conteúdo principal
Canon Powershot Pro1 LCD Screen Replacement
Seana Meegan
Seana Meegan e 3 outros colaboradores
Última atualização em May 7, 2024
35 minutos
Difícil
Ferramentas incorretas
Introdução
Ir para o passo 1
If the LCD of your Canon Powershot Pro1, follow this guide. The LCD provides the user with several features; such as the ability to view pictures and changing settings. If your LCD is damaged, your images may appear distorted. In this case, it is important to replace your LCD screen. Be sure to use ESD safe tools and remove the battery prior to disassembly. Also, be careful when removing the cables. They are essential to the operation of the LCD.
O que você precisa
Ferramentas
Exibir mais…
  1. Canon Powershot Pro1 LCD Screen Replacement, Battery: passo 1, imagem 1 %32
    • Locate the battery compartment cover on the right hand side of the camera. The cover features the text: “CF/BATT.OPEN”.
  2. Canon Powershot Pro1 LCD Screen Replacement: passo 2, imagem 1 %32
    • There is an arrow beside the text. Using your hands, slide the cover in the direction of this arrow.
  3. Canon Powershot Pro1 LCD Screen Replacement: passo 3, imagem 1 %32
    • Pull the cover toward you. After doing so you will see the battery sitting inside the compartment.
  4. Canon Powershot Pro1 LCD Screen Replacement: passo 4, imagem 1 %32
    • Press the orange battery lock inside the compartment.
    • Remove the battery.
    • This photo show the battery compartment after the battery has been removed.
  5. Canon Powershot Pro1 LCD Screen Replacement, LCD screen: passo 5, imagem 1 %32
    • Open up the LCD screen.
  6. Canon Powershot Pro1 LCD Screen Replacement: passo 6, imagem 1 %32 Canon Powershot Pro1 LCD Screen Replacement: passo 6, imagem 2 %32
    • Remove the 1.2 mm Phillips #0 screws on the left and right side of the LCD.
    • Using the Phillips #000 screwdriver, remove the screws on the right (you need to rotate the screen to access the screws on the right, and you will see one on each corner).
  7. Canon Powershot Pro1 LCD Screen Replacement: passo 7, imagem 1 %32
    • Remove the back cover of the LCD screen (has “Canon” written on it).
  8. Canon Powershot Pro1 LCD Screen Replacement: passo 8, imagem 1 %32 Canon Powershot Pro1 LCD Screen Replacement: passo 8, imagem 2 %32 Canon Powershot Pro1 LCD Screen Replacement: passo 8, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Now you will see an exposed circuit board and the backside of the LCD.
    • Fold back the plastic covering and remove the highlighted ribbon cables with tweezers.
  9. Canon Powershot Pro1 LCD Screen Replacement: passo 9, imagem 1 %32
    • Using the nylon spudger, pry the LCD off the screen cover.
    • You can now separate the LCD from the camera.
    • Don't use a metal spudger as this could cause damage to the device.
Conclusão
1Comentário do guia
Hi, where do I get a replacement lcd screen for this is camera?
Dog EatDog - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 36
Ao todo: 945
