Canon PowerShot SX260 HS LCD Screen Replacement
Introdução
Ir para o passo 1If you need to replace your LCD Screen on your Canon PowerShot SX260 HS this guide is for you!
O que você precisa
Ferramentas
Exibir mais…
The camera has a total of 6 (3 mm) external screws that will need to be removed; 2 on the left side, 2 on the bottom, and 2 on the right side.
Remove the 2 (3 mm) screws on the left side
Remove the 2 (3 mm) screws on the bottom of the camera.
Remove the 2 (3 mm) screws on the right side of the camera.
3 outras pessoas executaram este guia.
