Canon PowerShot SX160 IS Shutter Button Replacement
Introdução
Vá para o passo 1This guide walks you through how to replace a shutter button on your Canon PowerShot SX160 IS by disassembling a portion of the camera to access the non operational piece.
O que você precisa
Ferramentas
Unscrew 2-4.8mm black screws from the front of the camera using a #0 Phillips screwdriver.
Unscrew 2-4.8mm black screws from the side of the camera using a #0 Phillips screwdriver.
Unscrew 2-4.8mm black screws from the bottom of the camera using a #0 Phillips screwdriver.
Congratulations, you have successfully replaced your shutter button. To reassemble your device, follow these instructions in reverse order.
2 comentários
Great guide on how to replace the shutter button. Where can I get the new button?
did you ever figure out where to get a new button?
