Ir para o conteúdo principal
Canon PowerShot SX160 IS LCD Replacement
Jamie Secretan
Jamie Secretan e um outro colaborador
Última atualização em June 22, 2015
15 - 30 minutos
Moderada
Despedaçar
This guide walks you through how to replace a broken LCD screen on your Canon PowerShot SX160 IS by disassembling a portion of the camera to access the non operational piece.
O que você precisa
Ferramentas
  1. Canon PowerShot SX160 IS LCD Replacement, LCD: passo 1, imagem 1 %32 Canon PowerShot SX160 IS LCD Replacement, LCD: passo 1, imagem 2 %32 Canon PowerShot SX160 IS LCD Replacement, LCD: passo 1, imagem 3 %32
    • Unscrew the 2-4.8mm black screws from the front of the camera using a #0 Phillips head screw driver.
    • Unscrew the 2-4.8mm black screws from the side of the camera using a #0 Phillips head screw driver.
    • Unscrew the 3-4.8mm black screws from the bottom of the camera using a #0 Phillips head screw driver.
  2. Canon PowerShot SX160 IS LCD Replacement: passo 2, imagem 1 %32 Canon PowerShot SX160 IS LCD Replacement: passo 2, imagem 2 %32
    • Use your hand to gently separate the back panel from the camera.
    • Continue to pull the panel until it becomes completely detached from the camera.
  3. Canon PowerShot SX160 IS LCD Replacement: passo 3, imagem 1 %32 Canon PowerShot SX160 IS LCD Replacement: passo 3, imagem 2 %32
    • Unscrew the 3-3.75mm silver screws from the function wheel panel of the camera using a #0 Phillips head screw driver.
    • Remove the function wheel panel from the camera and set aside.
  4. Canon PowerShot SX160 IS LCD Replacement: passo 4, imagem 1 %32
    • Unlatch the LCD ribbon connector from the camera by gently lifting up on the ribbon while pulling away from the camera.
    • Be extra cautious not to tear the ribbon.
  5. Canon PowerShot SX160 IS LCD Replacement: passo 5, imagem 1 %32
    • Using your hand, pull the LCD screen away from the camera and replace.
Conclusão
Congratulations, you have successfully replaced your LCD screen. To reassemble your device, follow these instructions in reverse order.
Jamie Secretan
Membro desde: 03/11/15
1.990 Reputação
Autoria de 6 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 34
Duração total: 1,523
