Canon PowerShot SX160 IS Format Wheel Replacement
Introdução
Ir para o passo 1This guide walks you through how to replace a format wheel on your Canon PowerShot SX160 IS by disassembling a portion of the camera to access the non operational piece.
O que você precisa
Ferramentas
Use a #0 phillips screwdriver to unscrew the two black 4.8mm phillips head screws from the back of the camera.
Congratulations, you have successfully replaced your format wheel. To reassemble your device, follow these instructions in reverse order.
