Ir para o conteúdo principal
Canon PowerShot SD850 IS LCD Screen Replacement
Peter Tran
Peter Tran e 4 outros colaboradores
Última atualização em December 14, 2017
20 - 30 minutos
Moderado
Imagens inconsistentes
Fotos de ação
Introdução
Ir para o passo 1
Use this repair guide to replace a broken LCD screen on your Canon PowerShot SD850 IS.
O que você precisa
Ferramentas
Exibir mais…
  1. Canon PowerShot SD850 IS LCD Screen Replacement, Battery: passo 1, imagem 1 %32 Canon PowerShot SD850 IS LCD Screen Replacement, Battery: passo 1, imagem 2 %32 Canon PowerShot SD850 IS LCD Screen Replacement, Battery: passo 1, imagem 3 %32
    • Slide the light grey tab toward the edge of the camera using your fingernail.
    • Pull the light grey tab up to open the door.
    • These photos do not show the camera’s memory card or battery, which should be visible inside.
  2. Canon PowerShot SD850 IS LCD Screen Replacement: passo 2, imagem 1 %32 Canon PowerShot SD850 IS LCD Screen Replacement: passo 2, imagem 2 %32
    • Slide the small brown tab toward the edge of the camera using your fingernail.
    • Let go of the brown tab when the battery pops up.
    • Grab battery and pull straight up to remove from holder.
    • When inserting the battery, orient it so that the terminals connect.
  3. Canon PowerShot SD850 IS LCD Screen Replacement, Case: passo 3, imagem 1 %32 Canon PowerShot SD850 IS LCD Screen Replacement, Case: passo 3, imagem 2 %32
    • Remove the following 4 screws:
    • Two 2.8 mm Phillips #00 at the bottom of the camera.
    • Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
  4. Canon PowerShot SD850 IS LCD Screen Replacement: passo 4, imagem 1 %32 Canon PowerShot SD850 IS LCD Screen Replacement: passo 4, imagem 2 %32 Canon PowerShot SD850 IS LCD Screen Replacement: passo 4, imagem 3 %32
    • Open the A/V OUT DIGITAL flap on the side of the wrist strap.
    • Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap.
  5. Canon PowerShot SD850 IS LCD Screen Replacement: passo 5, imagem 1 %32 Canon PowerShot SD850 IS LCD Screen Replacement: passo 5, imagem 2 %32
    • On the bottom of the camera, use your fingernail to slide the light gray tab towards the edge of the camera.
    • Slide light gray door and pull up to open the door.
    • Remove the 8.35 mm Phillips #00 next to the brown tab that holds the battery.
  6. Canon PowerShot SD850 IS LCD Screen Replacement: passo 6, imagem 1 %32 Canon PowerShot SD850 IS LCD Screen Replacement: passo 6, imagem 2 %32
    • Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera.
  7. Canon PowerShot SD850 IS LCD Screen Replacement: passo 7, imagem 1 %32
    • Remove the 2.75 mm Phillips #00 next to A/V OUT DIGITAL.
  8. Canon PowerShot SD850 IS LCD Screen Replacement: passo 8, imagem 1 %32
    • Slide the back casing (with the screen protector) off to reveal the LCD and back wiring.
  9. Canon PowerShot SD850 IS LCD Screen Replacement, LCD Screen: passo 9, imagem 1 %32
    • Remove the 1.75 mm Phillips #00 located at the top left of the LCD screen.
  10. Canon PowerShot SD850 IS LCD Screen Replacement: passo 10, imagem 1 %32
    • Remove the two 3.4 mm Phillips #00 located at the bottom of the camera.
  11. Canon PowerShot SD850 IS LCD Screen Replacement: passo 11, imagem 1 %32 Canon PowerShot SD850 IS LCD Screen Replacement: passo 11, imagem 2 %32
    • Remove the two metal frames that hold the LCD panel in place.
  12. Canon PowerShot SD850 IS LCD Screen Replacement: passo 12, imagem 1 %32
    • The LCD screen should now only be attached by two LCD data cables.
    • Lift the screen from the left side and use a spudger or a small flat head screwdriver to flip the black portion of the connector upward to unlock it.
    • Carefully slide the data cable out of the connector.
  13. Canon PowerShot SD850 IS LCD Screen Replacement: passo 13, imagem 1 %32
    • The LCD should still be connected by the backlight cable.
    • To remove the backlight cable, use a spudger or a small flat head screwdriver to unlock the backlight cable.
    • Carefully slide out the backlight cable.
    • The LCD screen can now be fully detached from the camera body.
  14. Canon PowerShot SD850 IS LCD Screen Replacement: passo 14, imagem 1 %32 Canon PowerShot SD850 IS LCD Screen Replacement: passo 14, imagem 2 %32
    • The LCD screen and housing are now in three pieces:
    • LCD screen
    • LCD screen frame
    • LCD back housing
    • The LCD screen itself can now be removed and fixed/replaced.
Conclusão
Uma outra pessoa concluiu este guia.
Peter Tran
Membro desde: 10/06/10
225 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 20-7, Maness Fall 2010 Membro de Cal Poly, Team 20-7, Maness Fall 2010
CPSU-MANESS-F10S20G7
6 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 22
Ao todo: 4,245
