Ir para o conteúdo principal
Canon PowerShot SD450 LCD Screen Replacement
Pierre Teplitxky
Pierre Teplitxky e 6 outros colaboradores
Última atualização em 19 de fev de 2016
15 - 30 minutos
Moderado
Introdução
Ir para o passo 1
Removing the LCD screen for replacement.
O que você precisa
Ferramentas
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
Exibir mais…
  1. Canon PowerShot SD450 LCD Screen Replacement, Casing: passo 1, imagem 1 %32
    • Remove the battery and SD Card from their slots. Leaving these in could cause the battery to ground and ruin the electronics.
    • Unscrew the six screws on the casing. Two are on the bottom as pictured; two more are on each side of the camera.
  2. Canon PowerShot SD450 LCD Screen Replacement: passo 2, imagem 1 %32
    • Pull the lanyard mount off of the camera using a spudger or your fingers.
  3. Canon PowerShot SD450 LCD Screen Replacement: passo 3, imagem 1 %32 Canon PowerShot SD450 LCD Screen Replacement: passo 3, imagem 2 %32
    • Find the line that separates the casing into its two halves. Hold each half separately, and gently pull apart.
    • Note that there is a small metal clip holding the two halves together. It might help to press down on the back half (indicated) while pulling upward slightly on the front half.
  4. Canon PowerShot SD450 LCD Screen Replacement: passo 4, imagem 1 %32
    • Take hold of the inside of the camera, and gently pull away from the back casing.
  5. Canon PowerShot SD450 LCD Screen Replacement: passo 5, imagem 1 %32
    • Remove the square, clear, rubber protector from the front of the logic board. This is not necessary to remove, but can easily fall off and get lost during later steps.
  6. Canon PowerShot SD450 LCD Screen Replacement: passo 6, imagem 1 %32
    • When you reassemble the camera, make sure the switch on the casing matches the position of the switch on the camera internals.
    • The black viewfinder padding can easily fall off the casing. Make sure you don't lose it when moving around parts.
  7. Canon PowerShot SD450 LCD Screen Replacement, LCD Screen: passo 7, imagem 1 %32 Canon PowerShot SD450 LCD Screen Replacement, LCD Screen: passo 7, imagem 2 %32
    • Pull the retaining clip up with the spudger or your finger and remove the ribbon from the socket.
  8. Canon PowerShot SD450 LCD Screen Replacement: passo 8, imagem 1 %32
    • Remove the tripod mount screw.
    • Turn the camera around so that the screen is facing you, and the camera is upright.
  9. Canon PowerShot SD450 LCD Screen Replacement: passo 9, imagem 1 %32
    • Remove the screw at the top right of the screen.
  10. Canon PowerShot SD450 LCD Screen Replacement: passo 10, imagem 1 %32
    • Lift up the screen to reveal the tripod mount screw.
  11. Canon PowerShot SD450 LCD Screen Replacement: passo 11, imagem 1 %32
    • Remove the last screw holding the tripod mount to the case. The LCD ribbon threads under the mount, so upon reinstallation, the ribbon will need to be threaded through before the mount is reattached. Take note of the tripod mount orientation.
  12. Canon PowerShot SD450 LCD Screen Replacement: passo 12, imagem 1 %32
    • Pull the back light ribbon from it's socket to remove the LCD completely. There is a little hole you can stick the spudger into to help release the ribbon.
    The new screen came without a black light ribbon will it work without it? Canon Powershot sd450
    Mike - Responder
Conclusão
4 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Pierre Teplitxky
Membro desde: 04/10/10
152 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 25-85, Amido Spring 2010 Membro de Cal Poly, Team 25-85, Amido Spring 2010
CPSU-AMIDO-S10S25G85
4 Membros
Autoria de 5 guias
3Comentários do guia
Followed the steps and replaced the broken screen. Now I get only a white screen when turning the camera on. It does take pictures but it won't show anything but a little red dotted arrow on the right hand side over the white screen. Do you have a clue of what is happening?
Roberto - Responder
Salve, dove posso acquistare un display?
Germano Tinari - Responder
Salve, sapreste dirmi dove posso acquistare un display?
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 36
Ao todo: 6,837
