Ir para o conteúdo principal
Canon PowerShot SD30 Control Panel Replacement
Diego Hughes
Diego Hughes e 2 outros colaboradores
Última atualização em May 7, 2024
10 - 15 minutos
Moderado
Guia do aluno destaque
Introdução
Ir para o passo 1
Use this guide to replace the control panel in your camera.
O que você precisa
Ferramentas
Exibir mais…
  1. Canon PowerShot SD30 Control Panel Replacement, Front Cover: passo 1, imagem 1 %32 Canon PowerShot SD30 Control Panel Replacement, Front Cover: passo 1, imagem 2 %32
    • Be sure to remove the wrist strap and battery before removing the cover.
    • Remove the two 2mm black screws that are located on the underside of the camera.
    • Remove the two 3mm silver screws from the right side of camera.
  2. Canon PowerShot SD30 Control Panel Replacement: passo 2, imagem 1 %32
    • Gently remove the front cover.
  3. Canon PowerShot SD30 Control Panel Replacement, Back Cover: passo 3, imagem 1 %32 Canon PowerShot SD30 Control Panel Replacement, Back Cover: passo 3, imagem 2 %32 Canon PowerShot SD30 Control Panel Replacement, Back Cover: passo 3, imagem 3 %32
    • Remove the wrist strap and battery before removing the back cover.
    • Remove the 2mm screw from the back of the camera.
    • Remove two 2mm screws from the bottom of the camera.
    • Remove two 2mm screws the left side of camera.
  4. Canon PowerShot SD30 Control Panel Replacement: passo 4, imagem 1 %32
    • Gently remove the back cover.
  5. Canon PowerShot SD30 Control Panel Replacement, Control Panel: passo 5, imagem 1 %32 Canon PowerShot SD30 Control Panel Replacement, Control Panel: passo 5, imagem 2 %32 Canon PowerShot SD30 Control Panel Replacement, Control Panel: passo 5, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use the tweezers to pull up on the piece of black plastic connected to the ribbon to unhook and remove the ribbon connected to the screen.
    • You also have to pull up on the top part of the control panel because it is connected to the metal by a sticky pad.
  6. Canon PowerShot SD30 Control Panel Replacement: passo 6, imagem 1 %32 Canon PowerShot SD30 Control Panel Replacement: passo 6, imagem 2 %32 Canon PowerShot SD30 Control Panel Replacement: passo 6, imagem 3 %32
    • Turn the camera over to the side with the lens and remove the ribbon on the left side.
    • After removing the ribbon there will be a second ribbon to remove that was hiding underneath the first ribbon.
  7. Canon PowerShot SD30 Control Panel Replacement: passo 7, imagem 1 %32
    • Lift up the button that connects to the power button of the camera so you can remove the control panel.
  8. Canon PowerShot SD30 Control Panel Replacement: passo 8, imagem 1 %32
    • Remove the control panel from the camera.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Ao todo: 292
