Ir para o conteúdo principal
Canon PowerShot SD1100 IS Function Buttons Replacement
Wyatt Chan
Wyatt Chan e 4 outros colaboradores
Última atualização em January 28, 2014
20 minutos
Moderado
Introdução
Ir para o passo 1
This guide should be used if our guide, "Cleaning Function Buttons", doesn't fix your function buttons.
O que você precisa
Ferramentas
  • Spudger
    Spudger
Exibir mais…
  1. Canon PowerShot SD1100 IS Function Buttons Replacement, Front and Rear Cover: passo 1, imagem 1 %32 Canon PowerShot SD1100 IS Function Buttons Replacement, Front and Rear Cover: passo 1, imagem 2 %32
    • Remove wrist strap and battery.
  2. Canon PowerShot SD1100 IS Function Buttons Replacement: passo 2, imagem 1 %32 Canon PowerShot SD1100 IS Function Buttons Replacement: passo 2, imagem 2 %32 Canon PowerShot SD1100 IS Function Buttons Replacement: passo 2, imagem 3 %32
    • Remove 2 screws from each side of the camera (4 total, 0.102 in).
    • Remove 2 screws from the bottom on the camera (0.138 in).
    • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
  3. Canon PowerShot SD1100 IS Function Buttons Replacement: passo 3, imagem 1 %32 Canon PowerShot SD1100 IS Function Buttons Replacement: passo 3, imagem 2 %32 Canon PowerShot SD1100 IS Function Buttons Replacement: passo 3, imagem 3 %32
    • Gently pull off the front cover.
    • The plate on the side should come off.
    • Gently pull off the back cover.
  4. Canon PowerShot SD1100 IS Function Buttons Replacement: passo 4, imagem 1 %32
    • The cases should now be removed.
  5. Canon PowerShot SD1100 IS Function Buttons Replacement, Top Button Assembly: passo 5, imagem 1 %32
    • Use the spudger to disconnect the black tab.
  6. Canon PowerShot SD1100 IS Function Buttons Replacement: passo 6, imagem 1 %32
    • Gently pull off the shutter button assembly.
  7. Canon PowerShot SD1100 IS Function Buttons Replacement: passo 7, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use the tweezers to disconnect the microphone cable.
  8. Canon PowerShot SD1100 IS Function Buttons Replacement: passo 8, imagem 1 %32
    • The shutter button assembly should now be removed.
  9. Canon PowerShot SD1100 IS Function Buttons Replacement, Function Buttons: passo 9, imagem 1 %32
    • With the spudger, flip up the black tab on the main ribbon.
  10. Canon PowerShot SD1100 IS Function Buttons Replacement: passo 10, imagem 1 %32 Canon PowerShot SD1100 IS Function Buttons Replacement: passo 10, imagem 2 %32
    • Gently pull straight out on the ribbon to disconnect it from the logic board.
  11. Canon PowerShot SD1100 IS Function Buttons Replacement: passo 11, imagem 1 %32
    • By hand, gently unfold the function button board and lift it off the frame.
  12. Canon PowerShot SD1100 IS Function Buttons Replacement: passo 12, imagem 1 %32
    • Congratulations! The function button board can now be replaced.
Conclusão
Wyatt Chan
Membro desde: 01/05/11
235 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 3-32, Regan Winter 2011 Membro de Cal Poly, Team 3-32, Regan Winter 2011
CPSU-REGAN-W11S3G32
3 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Ao todo: 2,017
