Canon PowerShot ELPH 310 HS Shutter Button Replacement
Introdução
Ir para o passo 1The Canon PowerShot Elph 310 HS may have issues with the shutter button sticking. Replacing the button should only take a few minutes with these steps.
O que você precisa
Ferramentas
Use the Phillips #000 screwdriver from the iFixit tool kit to unscrew the two image stabilizer panel’s 2 mm Phillips head screws.
Using your hands, remove the image stabilizer panel.
Using your hand, lift and remove the shutter button deck from the top of camera.
