Ir para o conteúdo principal
Canon PowerShot ELPH 150 IS  Back Plate/Menu Button Replacement
Alex Larrimore
Alex Larrimore e 7 outros colaboradores
Última atualização em June 28, 2024
10 minutos
Fácil
Introdução
Ir para o passo 1
This guide will help users remove the back plate and the menu buttons on the Canon PowerShot ELPH 150 IS camera in six simple steps!
O que você precisa
Ferramentas
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
Exibir mais…
  1. Canon PowerShot ELPH 150 IS  Back Plate/Menu Button Replacement, Back Plate/Menu Buttons: passo 1, imagem 1 %32 Canon PowerShot ELPH 150 IS  Back Plate/Menu Button Replacement, Back Plate/Menu Buttons: passo 1, imagem 2 %32
    • Locate the ON/Off button on the top of the camera and hold it down until the screen and all lights on the camera go dark.
  2. Canon PowerShot ELPH 150 IS  Back Plate/Menu Button Replacement: passo 2, imagem 1 %32
    • Locate the back plate of the camera (contains the LCD screen and menu buttons).
  3. Canon PowerShot ELPH 150 IS  Back Plate/Menu Button Replacement: passo 3, imagem 1 %32 Canon PowerShot ELPH 150 IS  Back Plate/Menu Button Replacement: passo 3, imagem 2 %32
    • To remove the back plate you will need to unscrew the 6 support screws securing it to the camera.
    • Use a Phillips #00 screwdriver to remove the first 2 screws on the bottom of the camera.
  4. Canon PowerShot ELPH 150 IS  Back Plate/Menu Button Replacement: passo 4, imagem 1 %32 Canon PowerShot ELPH 150 IS  Back Plate/Menu Button Replacement: passo 4, imagem 2 %32 Canon PowerShot ELPH 150 IS  Back Plate/Menu Button Replacement: passo 4, imagem 3 %32
    • Remove the next 2 screws located behind the AV port using the same Phillips #00 screwdriver.
  5. Canon PowerShot ELPH 150 IS  Back Plate/Menu Button Replacement: passo 5, imagem 1 %32 Canon PowerShot ELPH 150 IS  Back Plate/Menu Button Replacement: passo 5, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the final 2 screws from the blue side panel.
  6. Canon PowerShot ELPH 150 IS  Back Plate/Menu Button Replacement: passo 6, imagem 1 %32 Canon PowerShot ELPH 150 IS  Back Plate/Menu Button Replacement: passo 6, imagem 2 %32 Canon PowerShot ELPH 150 IS  Back Plate/Menu Button Replacement: passo 6, imagem 3 %32
    • Use your hands or a spudger to gently pry the front and back case apart along the seams on the bottom of the camera.
    • Completely remove the back plate.
Conclusão
Alex Larrimore
Membro desde: 03/05/17
305 Reputação
Autoria de 3 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 3
Últimos 30 dias: 8
Ao todo: 566
