Ir para o conteúdo principal
Canon PowerShot A620 Shutter Button Replacement
Jaime Abraham
Jaime Abraham e 3 outros colaboradores
Última atualização em March 21, 2020
15 - 30 minutos
Moderado
Precisa de melhores imagens
Melhor Introdução
O que você precisa
Ferramentas
  1. Canon PowerShot A620 Shutter Button Replacement, Side Panel: passo 1, imagem 1 %32 Canon PowerShot A620 Shutter Button Replacement, Side Panel: passo 1, imagem 2 %32 Canon PowerShot A620 Shutter Button Replacement, Side Panel: passo 1, imagem 3 %32
    • Unscrew the three Phillips #00 1.6x3mm screws on the side.
    • Lift loose panel from the case.
    • Unscrew the two Phillips #00 1.6x3mm screws that were previously hidden beneath the panel.
  2. Canon PowerShot A620 Shutter Button Replacement, Bottom Panel: passo 2, imagem 1 %32
    • Unscrew the two Phillips #00 1.6x3mm screws on the bottom panel.
  3. Canon PowerShot A620 Shutter Button Replacement, Battery Compartment: passo 3, imagem 1 %32
    • Open the battery door.
    • Unscrew the four Phillips #00 1.6x3mm screws in the battery compartment.
  4. Canon PowerShot A620 Shutter Button Replacement, Terminal Cover: passo 4, imagem 1 %32 Canon PowerShot A620 Shutter Button Replacement, Terminal Cover: passo 4, imagem 2 %32
    • Lift the terminal cover on the side of the camera.
    • Unscrew the three Phillips #00 1.6x3mm screws beneath the terminal cover.
  5. Canon PowerShot A620 Shutter Button Replacement, Top Panel: passo 5, imagem 1 %32
    • Gently pull the top panel to separate it from the case.
    • Although the top panel will now be free from the rest of the case, it will still be attached to the camera by a ribbon cable.
  6. Canon PowerShot A620 Shutter Button Replacement, Front Panel: passo 6, imagem 1 %32 Canon PowerShot A620 Shutter Button Replacement, Front Panel: passo 6, imagem 2 %32
    • Gently pull the front panel to separate it from the camera.
    • The battery terminals are easy to access from this step.
  7. Canon PowerShot A620 Shutter Button Replacement, Terminal Cover: passo 7, imagem 1 %32 Canon PowerShot A620 Shutter Button Replacement, Terminal Cover: passo 7, imagem 2 %32
    • Gently pull the terminal cover to separate it from the camera.
  8. Canon PowerShot A620 Shutter Button Replacement, Memory Card Cover: passo 8, imagem 1 %32 Canon PowerShot A620 Shutter Button Replacement, Memory Card Cover: passo 8, imagem 2 %32
    • Slide the memory card cover down.
    • Unscrew the Phillips #00 1.6x3mm screw beneath the memory card cover.
  9. Canon PowerShot A620 Shutter Button Replacement, Back Panel: passo 9, imagem 1 %32 Canon PowerShot A620 Shutter Button Replacement, Back Panel: passo 9, imagem 2 %32
    • Gently pull the back panel to separate it from the camera.
  10. Canon PowerShot A620 Shutter Button Replacement, Metal Plate Screws: passo 10, imagem 1 %32 Canon PowerShot A620 Shutter Button Replacement, Metal Plate Screws: passo 10, imagem 2 %32
    • Unscrew the Phillips #00 1.6x3mm screw located on the top panel.
  11. Canon PowerShot A620 Shutter Button Replacement, Metal Plate: passo 11, imagem 1 %32
    • Gently lift the metal plate and move it to the side.
  12. Canon PowerShot A620 Shutter Button Replacement, Trigger Button Screws: passo 12, imagem 1 %32 Canon PowerShot A620 Shutter Button Replacement, Trigger Button Screws: passo 12, imagem 2 %32
    • Unscrew the two Phillips #00 1.6x3mm screws that hold in the trigger button.
  13. Canon PowerShot A620 Shutter Button Replacement, Trigger Button: passo 13, imagem 1 %32
    • The trigger button will fall off once the screws have been removed.
Conclusão
Uma outra pessoa concluiu este guia.
Jaime Abraham
Membro desde: 09/08/14
350 Reputação
Autoria de 3 guias
Equipe
CSU Fullerton, Team 1-1, Bruce Fall 2014 Membro de CSU Fullerton, Team 1-1, Bruce Fall 2014
CSUF-BRUCE-F14S1G1
3 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 10
Ao todo: 1,485
