Ir para o conteúdo principal
Canon PowerShot A620 Camera Housing Replacement
Jaime Abraham
Jaime Abraham e 4 outros colaboradores
Última atualização em March 20, 2020
15 - 30 minutos
Moderada
Precisa de melhores imagens
Melhor Introdução
O que você precisa
Ferramentas
  1. Canon PowerShot A620 Camera Housing Replacement, Open Battery Door: passo 1, imagem 1 %32 Canon PowerShot A620 Camera Housing Replacement, Open Battery Door: passo 1, imagem 2 %32 Canon PowerShot A620 Camera Housing Replacement, Open Battery Door: passo 1, imagem 3 %32
    • Slide the tab on the battery door while pushing the battery door away from you. The battery door should pop open.
  2. Canon PowerShot A620 Camera Housing Replacement, Insert Batteries: passo 2, imagem 1 %32 Canon PowerShot A620 Camera Housing Replacement, Insert Batteries: passo 2, imagem 2 %32
    • Insert AA batteries according to the diagram printed on the camera.
    • Close the battery door.
  3. Canon PowerShot A620 Camera Housing Replacement, Side Panel: passo 3, imagem 1 %32 Canon PowerShot A620 Camera Housing Replacement, Side Panel: passo 3, imagem 2 %32 Canon PowerShot A620 Camera Housing Replacement, Side Panel: passo 3, imagem 3 %32
    • Unscrew the three Phillips #00 1.6x3mm screws on the side.
    • Lift loose panel from the case.
    • Unscrew the two Phillips #00 1.6x3mm screws that were previously hidden beneath the panel.
  4. Canon PowerShot A620 Camera Housing Replacement, Bottom Panel: passo 4, imagem 1 %32
    • Unscrew the two Phillips #00 1.6x3mm screws on the bottom panel.
  5. Canon PowerShot A620 Camera Housing Replacement, Battery Compartment: passo 5, imagem 1 %32
    • Open the battery door.
    • Unscrew the four Phillips #00 1.6x3mm screws in the battery compartment.
  6. Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: passo 6, imagem 1 %32 Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: passo 6, imagem 2 %32
    • Lift the terminal cover on the side of the camera.
    • Unscrew the three Phillips #00 1.6x3mm screws beneath the terminal cover.
  7. Canon PowerShot A620 Camera Housing Replacement, Top Panel: passo 7, imagem 1 %32
    • Gently pull the top panel to separate it from the case.
    • Although the top panel will now be free from the rest of the case, it will still be attached to the camera by a ribbon cable.
  8. Canon PowerShot A620 Camera Housing Replacement, Front Panel: passo 8, imagem 1 %32 Canon PowerShot A620 Camera Housing Replacement, Front Panel: passo 8, imagem 2 %32
    • Gently pull the front panel to separate it from the camera.
    • The battery terminals are easy to access from this step.
  9. Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: passo 9, imagem 1 %32 Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: passo 9, imagem 2 %32
    • Gently pull the terminal cover to separate it from the camera.
  10. Canon PowerShot A620 Camera Housing Replacement, Memory Card Cover: passo 10, imagem 1 %32 Canon PowerShot A620 Camera Housing Replacement, Memory Card Cover: passo 10, imagem 2 %32
    • Slide the memory card cover down.
    • Unscrew the Phillips #00 1.6x3mm screw beneath the memory card cover.
  11. Canon PowerShot A620 Camera Housing Replacement, Back Panel: passo 11, imagem 1 %32 Canon PowerShot A620 Camera Housing Replacement, Back Panel: passo 11, imagem 2 %32
    • Gently pull the back panel to separate it from the camera.
Conclusão
Jaime Abraham
Membro desde: 09/08/14
350 Reputação
Autoria de 3 guias
Equipe
CSU Fullerton, Team 1-1, Bruce Fall 2014 Membro de CSU Fullerton, Team 1-1, Bruce Fall 2014
CSUF-BRUCE-F14S1G1
Membros da 3
Autoria de 6 guias
Um comentário
Ottima spiegazione: é tutto facile quando la spiegazione é semplice ed univoca. Ma redigere istruzioni semplici é un'arte che non tutti possiedono.
Paolo Ravera - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 20
Últimos 30 dias: 31
Duração total: 1,782
