Ir para o conteúdo principal
Canon PowerShot A460 LCD Screen Replacement
Alex
Alex e 8 outros colaboradores
Última atualização em January 8, 2024
35 minutos
Moderado
Precisa de mais images
Fotos de ação
Melhor Introdução
Introdução
Ir para o passo 1
Involving removal of the camera casing as well, this guide will help the user remove the LCD screen to repair or replace it.
O que você precisa
Ferramentas
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
Exibir mais…
  1. Canon PowerShot A460 LCD Screen Replacement, Battery: passo 1, imagem 1 %32
    • Slide the switch on the battery cover labeled "CARD/BATT. OPEN." to the right.
    • While still holding the switch, pull the cover down, allowing it to release and open.
  2. Canon PowerShot A460 LCD Screen Replacement: passo 2, imagem 1 %32
    • Tilt the camera slightly to allow the batteries to fall out.
  3. Canon PowerShot A460 LCD Screen Replacement: passo 3, imagem 1 %32
    • Press on and release the memory card to eject it.
  4. Canon PowerShot A460 LCD Screen Replacement, Front Casing: passo 4, imagem 1 %32
    • Unscrew the 5mm Phillips #00 screw from the bottom of the camera.
    • Make sure to keep the different size screws organized to make reassembling the camera simpler.
  5. Canon PowerShot A460 LCD Screen Replacement: passo 5, imagem 1 %32
    • Unscrew the three 2mm Phillips #00 screws that are located on the bottom of the camera.
  6. Canon PowerShot A460 LCD Screen Replacement: passo 6, imagem 1 %32
    • Remove the 4mm Phillips #00 screw that is located on the left side of the camera, if the display screen is facing you.
  7. Canon PowerShot A460 LCD Screen Replacement: passo 7, imagem 1 %32
    • Take out the 4mm Phillips #00 screw under the rubber flap on the right end of the camera.
  8. Canon PowerShot A460 LCD Screen Replacement: passo 8, imagem 1 %32 Canon PowerShot A460 LCD Screen Replacement: passo 8, imagem 2 %32
    • Remove the second battery cover on the bottom of camera.
    • Take the silver battery out of the camera.
  9. Canon PowerShot A460 LCD Screen Replacement: passo 9, imagem 1 %32 Canon PowerShot A460 LCD Screen Replacement: passo 9, imagem 2 %32 Canon PowerShot A460 LCD Screen Replacement: passo 9, imagem 3 %32
    • Remove the 4mm Phillips #00 screw on the inside of the flap that hides the battery and memory card slots.
    • Remove the light grey, plastic piece.
    • Remove the plastic portion of the battery flap cover. The metal piece will remain attached.
  10. Canon PowerShot A460 LCD Screen Replacement: passo 10, imagem 1 %32 Canon PowerShot A460 LCD Screen Replacement: passo 10, imagem 2 %32 Canon PowerShot A460 LCD Screen Replacement: passo 10, imagem 3 %32
    • Slightly pull on each side of the camera. It should loosen up and come apart.
    • If it does not pull apart right away, use a little more force.
    • Do not give up!
  11. Canon PowerShot A460 LCD Screen Replacement, Back Casing: passo 11, imagem 1 %32
    • Remove the back case of the camera by pulling from the top.
    • Be careful when pulling off the case. There is a delicate gold ribbon connecting the bottom of the camera to the back case.
  12. Canon PowerShot A460 LCD Screen Replacement, LCD Screen: passo 12, imagem 1 %32
    • Remove the 4mm Phillips #00 screw from above the ribbon.
  13. Canon PowerShot A460 LCD Screen Replacement: passo 13, imagem 1 %32
    • Gently peel off the blue tape on the top of the LCD screen.
  14. Canon PowerShot A460 LCD Screen Replacement: passo 14, imagem 1 %32
    • Remove the 4mm Phillips #00 screw previously concealed by the blue tape.
  15. Canon PowerShot A460 LCD Screen Replacement: passo 15, imagem 1 %32
    • Gently lift the LCD screen off of the front casing by pulling up a tab on the side of the camera.
  16. Canon PowerShot A460 LCD Screen Replacement: passo 16, imagem 1 %32
    • Using a spudger, lift the grey tabs to allow the ribbon to slide out.
    Where to buy those grey tabs? Mine was broken during removing of ribbon
    Mark Y - Responder
  17. Canon PowerShot A460 LCD Screen Replacement: passo 17, imagem 1 %32
    • Since the tabs have been lifted, the ribbon should now slide out out easily.
    • Be careful not to distort the ribbon in any way.
    Thank you very much for the good knowledge that I can do by myself.
    K201
    Rachsuthee waiP - Responder
Conclusão
3 outras pessoas executaram este guia.
Alex
Membro desde: 01/18/13
85 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 19-42, Regan Winter 2013 Membro de Cal Poly, Team 19-42, Regan Winter 2013
CPSU-REGAN-W13S19G42
4 Membros
Autoria de 12 guias
2Comentários do guia
Thanks for this super documented guide.
I did it!! I found a second hand lcd on Ebay.
Now my camera is working again.
Super DIY guide!! Thanks a lot!!
Pierre - Responder
Explained in detail, very clear, easy to understand. I just unpacked it for the first time. Still able to do as told. Thank you.
Rachsuthee Waiprib - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 19
Ao todo: 1,609
