Ir para o conteúdo principal
Canon EOS Rebel XSi LCD Screen Replacement
Erik Mork
Erik Mork e 5 outros colaboradores
Última atualização em February 15, 2020
Nenhuma estimativa
Moderado
Introdução
Ir para o passo 1
This replacement guide shows how to remove the camera's LCD screen. The back panel must be removed before hand.
O que você precisa
Ferramentas
Exibir mais…
  1. Canon EOS Rebel XSi LCD Screen Replacement, Back Panel: passo 1, imagem 1 %32
    • Squeeze the eyepiece between your index finger and thumb and lift up and off.
  2. Canon EOS Rebel XSi LCD Screen Replacement: passo 2, imagem 1 %32
    • Using the PH000 screwdriver head, remove the four 4 mm screws on the bottom of the camera.
  3. Canon EOS Rebel XSi LCD Screen Replacement: passo 3, imagem 1 %32
    • Using the PH000 screwdriver head, remove the two 3mm screws on the right side of the camera (from the LCD screen).
  4. Canon EOS Rebel XSi LCD Screen Replacement: passo 4, imagem 1 %32
    • Remove grip by slowly peeling off.
  5. Canon EOS Rebel XSi LCD Screen Replacement: passo 5, imagem 1 %32
    • Using the PH000 screwdriver, remove the four 4mm screws behind the eyepiece.
  6. Canon EOS Rebel XSi LCD Screen Replacement: passo 6, imagem 1 %32
    • Using the PH000 screwdriver head, remove one 4 mm screw on the left side of the camera (from the LCD screen).
  7. Canon EOS Rebel XSi LCD Screen Replacement: passo 7, imagem 1 %32
    • Remove the side panel by lifting off with fingers.
  8. Canon EOS Rebel XSi LCD Screen Replacement: passo 8, imagem 1 %32
    • Use hands to pry off the back panel.
  9. Canon EOS Rebel XSi LCD Screen Replacement, LCD Screen: passo 9, imagem 1 %32
    • Using the PH00 screwdriver head, unscrew four 4 mm screws and one 2 mm screw
  10. Canon EOS Rebel XSi LCD Screen Replacement: passo 10, imagem 1 %32 Canon EOS Rebel XSi LCD Screen Replacement: passo 10, imagem 2 %32
    • Remove the metal plate covering inside of the LCD screen
  11. Canon EOS Rebel XSi LCD Screen Replacement: passo 11, imagem 1 %32
    • Carefully disconnect the circuitry sheets from the white plastic bases
  12. Canon EOS Rebel XSi LCD Screen Replacement: passo 12, imagem 1 %32 Canon EOS Rebel XSi LCD Screen Replacement: passo 12, imagem 2 %32
    • Using the plastic spudger, carefully pry out the LCD screen from the back panel
Conclusão
Erik Mork
Membro desde: 01/27/17
617 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 22-10, Maness Winter 2017 Membro de Cal Poly, Team 22-10, Maness Winter 2017
CPSU-MANESS-W17S22G10
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 38
Ao todo: 1,966
