Ir para o conteúdo principal
Canon EOS Rebel T6i LCD Display Replacement
Shane Riding
Shane Riding e 7 outros colaboradores
Última atualização em August 15, 2024
25 minutos
Moderado
Precisa de melhores imagens
Introdução
Ir para o passo 1
The Canon EOS T6i was a camera produced and sold by Canon in 2015. The functionality of the LCD screen is to produce high resolution images of the photos taken by the camera and to adjust any settings within the camera. In any case where your Canon EOS T6i LCD screen is: cracked,damaged,fading or not functional; this guide will show you how to safely disassembly and remove the screen from the camera for replacement.
O que você precisa
Ferramentas
Exibir mais…
  1. Canon EOS Rebel T6i LCD Display Replacement, LCD Display: passo 1, imagem 1 %32
    • Remove the battery and use an anti-static wrist strap to ground yourself to prevent damage to device.
    • 2 screws on the side -1.3 mm
    Where did you purchase the replacement LCD?
    Chris Mitchell - Responder
  2. Canon EOS Rebel T6i LCD Display Replacement: passo 2, imagem 1 %32 Canon EOS Rebel T6i LCD Display Replacement: passo 2, imagem 2 %32
    • 4 screws are located on the opposite/interior side of screen case. Use the J000 gauge screw driver head to remove these 4 screws. Furthermore, these screws are a larger gauge then the other 2. Please sort these accordingly.
    • 4 small screws on back 1.58 mm
  3. Canon EOS Rebel T6i LCD Display Replacement: passo 3, imagem 1 %32 Canon EOS Rebel T6i LCD Display Replacement: passo 3, imagem 2 %32
    • Following the removal of the 6 screws, Locate the joint of the casing. Place a flat lever inside this crevice and apply pressure. The case should simply pop open into the 2 casing pieces and the screen mechanism. Warning. No Dot try to remove bottom casing until next step.
  4. Canon EOS Rebel T6i LCD Display Replacement: passo 4, imagem 1 %32 Canon EOS Rebel T6i LCD Display Replacement: passo 4, imagem 2 %32 Canon EOS Rebel T6i LCD Display Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    • There are several components inside the casing. A board, a power cable, the screen and a ribbon cable. First, using tweezers lift the metallic clamp connecting the ribbon to the board.
    • WARNING. If the lever doesn't lift immediately, do not forcefully lift it. This could damage the ribbon and board. When reapplying the ribbon, secure connection.
  5. Canon EOS Rebel T6i LCD Display Replacement: passo 5, imagem 1 %32
    • Now that the ribbon is disconnected, remove the board carefully and place it aside. This piece still works so leave it attached to camera.
  6. Canon EOS Rebel T6i LCD Display Replacement: passo 6, imagem 1 %32 Canon EOS Rebel T6i LCD Display Replacement: passo 6, imagem 2 %32
    • The screen is glued into the casing. Remove the screen by carefulyl lifting along the edges of the case until the screen pops out. Place new screen into the existing casing. A small about of glue or adhesive may be necessary if their isn't sufficient adhesive remaining in the case. Repeat steps in reverse to reapply screen.
  7. Canon EOS Rebel T6i LCD Display Replacement: passo 7, imagem 1 %32
    • If screen doesn't power on after replacing the battery, Go back and check connections of the ribbon.
Conclusão
Uma outra pessoa concluiu este guia.
3Comentários do guia
Very simple and great guide for. See the Canon T6i Bundle
Deve Lee - Responder
Thanks for this awesome guide its really useful for me. see the Canon 80D Bundle
9 Product Reviews - Responder
y las refacciones donde?
cafeplazay - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 26
Ao todo: 4,421
