Ir para o conteúdo principal
Canon EOS 70D Camera Motherboard Replacement
Tyler Baker
Tyler Baker e 4 outros colaboradores
Última atualização em May 7, 2024
40 minutos - 1 hora
Difícil
Guia do aluno destaque
Introdução
Ir para o passo 1
The main motherboard controls all functions of the camera.
O que você precisa
Ferramentas
Exibir mais…
  1. Canon EOS 70D Camera Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Hold the camera with the lens pointing down. Press the highlighted button with your finger to release the cover.
    • Pull cover over to expose the battery.
  2. Canon EOS 70D Camera Motherboard Replacement: passo 2, imagem 1 %32 Canon EOS 70D Camera Motherboard Replacement: passo 2, imagem 2 %32
    • Press the white button with your finger to release the battery.
    • Once released, the battery will eject out about two inches
  3. Canon EOS 70D Camera Motherboard Replacement: passo 3, imagem 1 %32
    • Pull battery out of the camera.
  4. Canon EOS 70D Camera Motherboard Replacement, LCD Touchscreen: passo 4, imagem 1 %32 Canon EOS 70D Camera Motherboard Replacement, LCD Touchscreen: passo 4, imagem 2 %32
    • Pull Touchscreen out and rotate 90 degrees. Remove the four 3 mm Phillips #000 head screws that are now exposed at the hinge.
    • Remove the two 5 mm Phillips #000 head screws that near the viewfinder.
    • Use a spudger and pry apart the two plastic columns surrounding the screen hinge.
    • The screen will not be removed at this step.
    • Rotate the screen forward 90 degrees and push it back into its housing against the camera.
  5. Canon EOS 70D Camera Motherboard Replacement: passo 5, imagem 1 %32 Canon EOS 70D Camera Motherboard Replacement: passo 5, imagem 2 %32
    • Use a spudger to peel rubber matting on left hand side to expose camera backplate mounting screws.
    • Remove three 4 mm Phillip #000 head screws that mount the backplate to the left side of camera.
  6. Canon EOS 70D Camera Motherboard Replacement: passo 6, imagem 1 %32 Canon EOS 70D Camera Motherboard Replacement: passo 6, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to pry rubber matting on right hand side to expose backplate mounting screws.
    • Remove four 4 mm Phillips #000 head screws that mount the backplate to the right side of camera.
  7. Canon EOS 70D Camera Motherboard Replacement: passo 7, imagem 1 %32 Canon EOS 70D Camera Motherboard Replacement: passo 7, imagem 2 %32 Canon EOS 70D Camera Motherboard Replacement: passo 7, imagem 3 %32
    • Turn camera upside down. Remove five 5 mm Phillips #000 head screws securing the backplate to the bottom of the camera.
    • Grab the backplate and gently pull away from camera.
    • The backplate will still be attached by the wires running to the LCD touchscreen.
    • The screen will still be attached to the camera and won't be removed until step 10.
  8. Canon EOS 70D Camera Motherboard Replacement: passo 8, imagem 1 %32 Canon EOS 70D Camera Motherboard Replacement: passo 8, imagem 2 %32
    • Carefully pry open backplate from camera to expose LCD connector (white wire). LCD connector is attached with a metal bar to the motherboard.
    • Use tweezers to gently pry metal bar connector from camera motherboard.
  9. Canon EOS 70D Camera Motherboard Replacement: passo 9, imagem 1 %32 Canon EOS 70D Camera Motherboard Replacement: passo 9, imagem 2 %32
    • Remove two 4 mm Phillips #000 head screws that mount the LCD touchscreen to the hinge on the camera.
  10. Canon EOS 70D Camera Motherboard Replacement: passo 10, imagem 1 %32 Canon EOS 70D Camera Motherboard Replacement: passo 10, imagem 2 %32 Canon EOS 70D Camera Motherboard Replacement: passo 10, imagem 3 %32
    • Grip the screen with your hand and gently pull white connecting wire through hole in backplate.
    • Once the connector reaches the hole, twist the connector and pull completely through hole.
    • You must twist the connector in order to fit through hole.
    On mine a EOS 70D(W) there were 2 screws on the other side of the case under the mats that also had to be removed and screws on the plastic hinge covers as well. Of course I also had to take the LCD case apart as the replacement I got was just the LCD not the entire unit.
    Michael Ault - Responder
  11. Canon EOS 70D Camera Motherboard Replacement, Camera Motherboard: passo 11, imagem 1 %32 Canon EOS 70D Camera Motherboard Replacement, Camera Motherboard: passo 11, imagem 2 %32 Canon EOS 70D Camera Motherboard Replacement, Camera Motherboard: passo 11, imagem 3 %32
    • Use spudger to lift edge of black heat tape.
    • Slowly peel back black heat tape.
    When I did this step, it occurred to me you may not need to peel the black heat tape from the heat spreader.
    netguy - Responder
  12. Canon EOS 70D Camera Motherboard Replacement: passo 12, imagem 1 %32 Canon EOS 70D Camera Motherboard Replacement: passo 12, imagem 2 %32 Canon EOS 70D Camera Motherboard Replacement: passo 12, imagem 3 %32
    • Very carefully, use spudger to remove nine orangish ribbon cables.
    • Using tweezers remove the two wire cables shown.
    • Slowly remove ribbon cables because they can tear very easily.
  13. Canon EOS 70D Camera Motherboard Replacement: passo 13, imagem 1 %32 Canon EOS 70D Camera Motherboard Replacement: passo 13, imagem 2 %32 Canon EOS 70D Camera Motherboard Replacement: passo 13, imagem 3 %32
    • Remove seven 5 mm Phillips #000 head screws around motherboard.
    • Once the five screws are removed, remove the metal chip covered by hand.
    • This will leave the mother board exposed, attached by two cable wires underneath.
  14. Canon EOS 70D Camera Motherboard Replacement: passo 14, imagem 1 %32 Canon EOS 70D Camera Motherboard Replacement: passo 14, imagem 2 %32 Canon EOS 70D Camera Motherboard Replacement: passo 14, imagem 3 %32
    • Slowly lift motherboard to expose the two cable wires underneath.
    • Using tweezers, unattach the two wire cables holding the motherboard in.
  15. Canon EOS 70D Camera Motherboard Replacement: passo 15, imagem 1 %32
    • Carefully remove motherboard.
Conclusão
15 outras pessoas executaram este guia.
5Comentários do guia
Great write up and illustrations. I'm in the process of repairing a 70D and this will be a great help.
Thank you and keep up the good work!
marcuscleveland85 - Responder
Hi, do you know if after replacing the main board it is necessary to configure the camera with some software ? (I heard of spt software)
Stephen Lay -
Hi Tyler my Canon Camera eos 70D isn’t working anymore is it possible to replace the motherboard?
Charlie Laguna - Responder
Je suis à recherche de la carte mère de mon canon 70D. Puis je avoir de l’aide s’il vous plaît. Merci
Mahamadou DEMBELE - Responder
Je suis à la recherche d'une carte mère Pour canon EOS 70d. Aidez-moi svp
kindambi jython - Responder
Comentar
Visualizações:
Últimas 24 horas: 10
Últimos 7 dias: 52
Últimos 30 dias: 225
Ao todo: 18,337
