Ir para o conteúdo principal
Canon EOS 70D Battery Replacement
Paul
Paul e 2 outros colaboradores
Última atualização em February 23, 2024
5 minutos
Muito fácil
Introdução
Ir para o passo 1
The LP-E6 lithium battery is crucial to the operation of the Canon EOS 70D camera. Without the battery, the camera will not turn on. This guide will ensure you're able to properly replace the battery.
  1. Canon EOS 70D Battery Replacement, Battery: passo 1, imagem 1 %32
    • Hold the camera with the lens pointing down. Press the highlighted button with your finger to release the cover.
    • Pull cover over to expose the battery.
  2. Canon EOS 70D Battery Replacement: passo 2, imagem 1 %32 Canon EOS 70D Battery Replacement: passo 2, imagem 2 %32
    • Press the white button with your finger to release the battery.
    • Once released, the battery will eject out about two inches
  3. Canon EOS 70D Battery Replacement: passo 3, imagem 1 %32
    • Pull battery out of the camera.
Conclusão
Paul
Membro desde: 03/12/18
900 Reputação
Autoria de 3 guias
1Comentário do guia
I want replacement of battery. I bought the camera in Dubai.
Now Iam in chennai- India. where I will get it in chennai.
Krishna moorthy Thiagarajan - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 40
Ao todo: 3,066
