Canon EOS 6D Rear LCD Screen Replacement
Introdução
Ir para o passo 1Use this guide to replace a cracked or malfunctioning rear LCD screen on your EOS 6D.
O que você precisa
Remove the viewfinder cover by pinching the sides and sliding it upward.
Ferramenta utilizada neste passo:Tweezers$4.99
Detach the two light brown ribbon wires from the back of the LCD screen by firmly gripping each with tweezers and gently pulling straight to the left.
12 outras pessoas executaram este guia.
5Comentários do guia
Thank you! Thank you!! I rescued my 6D. All your steps and details were very useful.
Few points to add:
1. I think the black screw (yellow circle) from step 7 is 3 mm.
2. Lift the light brown flap that holds the ribbon cable before removing the LCD panel.
3. When you remove the LCD panel from the metal housing, you will have to pry the two strips of adhesive that is there.
4. Be careful when tightening the screws back.
