Ir para o conteúdo principal
Canon EOS 6D MIC Port and Remote Socket Replacement
Justin Thomas
Justin Thomas e 3 outros colaboradores
Última atualização em February 3, 2020
50 minutos
Moderado
Introdução
Ir para o passo 1
Use this guide to replace a nonfunctional MIC Port or Remote Socket on your EOS 6D.
O que você precisa
Ferramentas
Exibir mais…
  1. Canon EOS 6D MIC Port and Remote Socket Replacement, Rear Body Panel: passo 1, imagem 1 %32
    • Remove the viewfinder cover by pinching the sides and sliding it upward.
  2. Canon EOS 6D MIC Port and Remote Socket Replacement: passo 2, imagem 1 %32
    • Open the battery door on the bottom of the camera.
    • Use your thumb to slide the small black tab on the inside of the battery door up and pull the door off the camera.
  3. Canon EOS 6D MIC Port and Remote Socket Replacement: passo 3, imagem 1 %32
    • Slide your fingernail or the flat end of the spudger underneath the rubber covering and gently peel it off all sides of the camera.
  4. Canon EOS 6D MIC Port and Remote Socket Replacement: passo 4, imagem 1 %32
    • Open the covers to the HDMI/AV/MIC ports on the side of the camera by gently pulling outward on the bottom of the covers.
    • Rotate the covers to the side so that you can see the connection ports inside.
    • Remove the following screws:
    • Two silver 5mm Phillips #00
    • One black 6mm Phillips #00
  5. Canon EOS 6D MIC Port and Remote Socket Replacement: passo 5, imagem 1 %32
    • Remove the cover to the HDMI/AV/MIC ports by gently lifting the tab on the bottom edge of the camera.
  6. Canon EOS 6D MIC Port and Remote Socket Replacement: passo 6, imagem 1 %32
    • Rotate your camera so the bottom side is facing you.
    • One 6mm Phillips #00
    • Two 3mm Phillips #00
  7. Canon EOS 6D MIC Port and Remote Socket Replacement: passo 7, imagem 1 %32
    • Rotate your camera so the back is facing you.
    • Three silver 5mm Phillips #00
    • Two black 6mm Phillips #00
    • One black 4mm Phillips #00
  8. Canon EOS 6D MIC Port and Remote Socket Replacement: passo 8, imagem 1 %32 Canon EOS 6D MIC Port and Remote Socket Replacement: passo 8, imagem 2 %32
    • A black ribbon wire connects the rear panel to the inside of the camera. Breaking this wire would make your rear screen and buttons non-functional.
    • Carefully use your fingers to tilt the back panel downward to about a 90 degree angle.
    • Use the flat end of the spudger to gently pry off the ribbon wire from the inside of the camera.
  9. Canon EOS 6D MIC Port and Remote Socket Replacement, Front and Top Body Panels: passo 9, imagem 1 %32
    • Remove the 8mm Phillips #00 screw from the bottom of the front of the camera.
  10. Canon EOS 6D MIC Port and Remote Socket Replacement: passo 10, imagem 1 %32
    • Rotate the camera so the side with the SD card slot is facing you.
    • Remove the 4mm Phillips #00 screw from the bottom edge of this side.
  11. Canon EOS 6D MIC Port and Remote Socket Replacement: passo 11, imagem 1 %32
    • Rotate the camera so the bottom is facing you.
    • Two 8mm Phillips #00
    • One 4mm Phillips #00
  12. Canon EOS 6D MIC Port and Remote Socket Replacement: passo 12, imagem 1 %32
    • Remove the bottom panel from the camera by using your fingers to pull outward on the tab inside the battery compartment.
  13. Canon EOS 6D MIC Port and Remote Socket Replacement: passo 13, imagem 1 %32
    • Rotate the camera so the front is facing you.
    • Three 5mm Phillips #00
    • Two 6mm Phillips #00
  14. Canon EOS 6D MIC Port and Remote Socket Replacement: passo 14, imagem 1 %32
    • One 4mm fine-thread Phillips #00
    • Two 4mm coarse-thread Phillips #00
  15. Canon EOS 6D MIC Port and Remote Socket Replacement: passo 15, imagem 1 %32
    • The red speaker wire is attached to the inside of the front panel. Opening the front panel forcefully may break it.
    • Slowly fold the front panel to the right without pulling it away from the right edge of the camera.
  16. Canon EOS 6D MIC Port and Remote Socket Replacement: passo 16, imagem 1 %32
    • Remove the 4mm Phillips #00 screw on the inside of the front panel to separate the panel from the speaker wire.
  17. Canon EOS 6D MIC Port and Remote Socket Replacement: passo 17, imagem 1 %32
    • Remove the 4mm Phillips #00 screw from the inside of the top panel, below the strap hook.
  18. Canon EOS 6D MIC Port and Remote Socket Replacement: passo 18, imagem 1 %32
    • Remove the 4mm Phillips #00 screw from the inside of the top panel, below the shutter button.
  19. Canon EOS 6D MIC Port and Remote Socket Replacement: passo 19, imagem 1 %32
    • Rotate the camera so the top is facing you.
    • Remove the 6mm Phillips #00 screw from next to the analog screen.
  20. Canon EOS 6D MIC Port and Remote Socket Replacement: passo 20, imagem 1 %32
    • Rotate the camera so the back is facing you.
    • Remove the Phillips #00 screw from the viewfinder focus.
  21. Canon EOS 6D MIC Port and Remote Socket Replacement: passo 21, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Carefully detach the two light brown ribbon wires on the top panel:
    • The right ribbon by prying it out with the flat end of the spudger.
    • The left ribbon by using tweezers to gently wiggle it out toward the top.
  22. Canon EOS 6D MIC Port and Remote Socket Replacement: passo 22, imagem 1 %32
    • A ribbon wire connects the inside of the top panel to the body of the camera.
    • Slowly lift the top panel to about an inch above the body of the camera.
    • Carefully use the flat end of the spudger to detach the ribbon wire from the top of the camera.
  23. Canon EOS 6D MIC Port and Remote Socket Replacement: passo 23, imagem 1 %32
    • Grip the remaining side panel with your fingers and gently pop it off the camera.
  24. Canon EOS 6D MIC Port and Remote Socket Replacement, MIC Port and Remote Socket: passo 24, imagem 1 %32
    • Use the spudger to remove the light brown ribbon wire from the bottom edge of the camera.
  25. Canon EOS 6D MIC Port and Remote Socket Replacement: passo 25, imagem 1 %32
    • Rotate the camera so the side with the MIC port is facing you.
    • Remove the 4mm Phillips #00 screw from above the MIC port.
  26. Canon EOS 6D MIC Port and Remote Socket Replacement: passo 26, imagem 1 %32 Canon EOS 6D MIC Port and Remote Socket Replacement: passo 26, imagem 2 %32
    • Use the flat end of the spudger to gently lift up on the right side of the port.
    • Grip the sides of the port with your fingers and gently wiggle it up and down while pulling outward to remove it.
Conclusão
Justin Thomas
Membro desde: 04/22/14
2.188 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 11-48, Amido Spring 2014 Membro de Cal Poly, Team 11-48, Amido Spring 2014
CPSU-AMIDO-S14S11G48
4 Membros
Autoria de 18 guias
Um comentário
Where i can buy the part, mic jack??
balmore - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 38
Ao todo: 5,309
