Canon EOS 40D Shutter Button Replacement
Introdução
Ir para o passo 1If your Canon EOS 40D camera’s shutter button is sticking or not working properly, use this guide to replace the shutter button.
A functional shutter button is necessary for any photographer to capture their work. Over time, the shutter button on a camera may become damaged or broken. If you notice your shutter button sticking or it is unable to function, consider replacing it for optimal use of your Canon EOS 40D.
Before using this guide, assess your shutter button for any trapped debris. Shutter buttons often become stuck when dust and grease gets trapped inside. A simple cleaning will oftentimes fix this issue without needing to replace the shutter button.
In order to complete the replacement, the front, back, and top coverings of the camera must be disassembled in order to access the shutter button.
O que você precisa
Peças
Ferramentas
Exibir mais…
Locate the battery compartment cover on the bottom of the camera below the shutter button.
Peel off the grip material from the body of the camera, exposing the screws.
Remove the three 5.0 mm Phillips #000 screws.
Remove the single 12.0 mm Phillips #000 screw.
Notice that the screw next to the strap loop also has to be removed in order to remove the top cover in step 16
Use the tip of a spudger to disconnect the ZIF connector on the left side of the camera.
Disconnect the ribbon cable securing the rear case to the motherboard.
Separate the rear case from the camera.
Ferramenta utilizada neste passo:Tweezers$4.99
Remove the cable running from the top of the camera to the black and white box.
Use a pair of precision tweezers to poke through the rubber coating and create a path for the wire to slide out.
Disconnect the wire by sliding it away from the rubber.
3 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all3Comentários do guia
Thanks for these instructions. I've successfully replaced the shutter button assembly on my Canon 50d using this guide.
