Ir para o conteúdo principal
Canon EOS 40D Shutter Assembly Replacement
leggman7
leggman7 e 3 outros colaboradores
Última atualização em July 7, 2021
4 horas
Difícil
Faltando Passos
Guia colaborativo
Introdução
Ir para o passo 1
An Error 99 is an non specific error which means that camera doesn't know or have a code for the problem. In my case the shutter assembly needed replacing. This was a fairly involved process for a beginner such as myself.
This is not a comprehensive guide but should be used in conjunction with the Canon Service Manual and youtube videos. I hope that some of the pictures I took along the way might help you identify or remember how each step works.
O que você precisa
  1. Canon EOS 40D Shutter Assembly Replacement, Shutter Assembly: passo 1, imagem 1 %32
    • Get the Canon 40D Service Repair Manual
    • Have a clean and organized workspace. I labelled plastic trays by step number and put all items for each step in a separate tray.
    • Watch a couple Youtube videos on this process
  2. Canon EOS 40D Shutter Assembly Replacement: passo 2, imagem 1 %32 Canon EOS 40D Shutter Assembly Replacement: passo 2, imagem 2 %32
    • Peel off rubber grips
  3. Canon EOS 40D Shutter Assembly Replacement: passo 3, imagem 1 %32
    • take off front piece
  4. Canon EOS 40D Shutter Assembly Replacement: passo 4, imagem 1 %32 Canon EOS 40D Shutter Assembly Replacement: passo 4, imagem 2 %32
    • take off rear
    • connectors disconnect by flipping black/brown tab up and sliding plastic tab out.
  5. Canon EOS 40D Shutter Assembly Replacement: passo 5, imagem 1 %32 Canon EOS 40D Shutter Assembly Replacement: passo 5, imagem 2 %32 Canon EOS 40D Shutter Assembly Replacement: passo 5, imagem 3 %32
    • Take off top cover
  6. Canon EOS 40D Shutter Assembly Replacement: passo 6, imagem 1 %32 Canon EOS 40D Shutter Assembly Replacement: passo 6, imagem 2 %32 Canon EOS 40D Shutter Assembly Replacement: passo 6, imagem 3 %32
    • take off bottom plate
    • disconnect and remove bottom board
  7. Canon EOS 40D Shutter Assembly Replacement: passo 7, imagem 1 %32
    • remove CMOS assembly
  8. Canon EOS 40D Shutter Assembly Replacement: passo 8, imagem 1 %32
    • remove metal back
    • remove and replace shutter assembly, transfering components that aren't on the new one
Conclusão
6 outras pessoas executaram este guia.
2Comentários do guia
how do you replace the bridge (male portion on camera) other than putting the card in a card reader
wareibevictoriap - Responder
how to replace the focus lock beeper
Dave Reitner - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 38
Ao todo: 7,714
