Ir para o conteúdo principal
Canon EOS 40D Date and Time Battery Replacement
Doug Kruse
Doug Kruse e 2 outros colaboradores
Última atualização em December 2, 2021
2 - 6 minutos
Muito fácil
Introdução
Ir para o passo 1
If your date and time battery needs to be replaced, follow this guide to replace it. The required date and time battery is a CR2016 lithium.
O que você precisa
  1. Canon EOS 40D Date and Time Battery Replacement, Battery: passo 1, imagem 1 %32
    • Locate the battery compartment cover on the bottom of the camera below the shutter button.
  2. Canon EOS 40D Date and Time Battery Replacement: passo 2, imagem 1 %32
    • Find the marked arrow on the battery compartment cover labeled "BATT. OPEN". Slide the lever following the arrow's direction and lift at the same time to release the latch.
  3. Canon EOS 40D Date and Time Battery Replacement: passo 3, imagem 1 %32
    • Release the lever and allow the battery compartment cover to completely open.
    • Remove the battery.
  4. Canon EOS 40D Date and Time Battery Replacement, Date and Time Battery: passo 4, imagem 1 %32 Canon EOS 40D Date and Time Battery Replacement, Date and Time Battery: passo 4, imagem 2 %32 Canon EOS 40D Date and Time Battery Replacement, Date and Time Battery: passo 4, imagem 3 %32
    • Remove the date and time battery holder by sliding it out of the slot.
  5. Canon EOS 40D Date and Time Battery Replacement: passo 5, imagem 1 %32
    • Remove the date and time battery from the battery holder.
Conclusão
9 outras pessoas executaram este guia.
Doug Kruse
Membro desde: 09/03/15
766 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 12-3, Blackwell Fall 2015 Membro de USF Tampa, Team 12-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G3
4 Membros
Autoria de 16 guias
6Comentários do guia
Thank you. This is fantastic information that is *not* in the manual. I bought an unnecessary main battery, but this resuscitated my camera on a trip.
Thanks! David D.
David Drinkwater - Responder
All the other advice I found says to remove two screws, when it's really as simple as you show here. Thanks!
Stephen Spratley - Responder
This was so helpful, thank you! Also if you are in a jam and do not have a CR2016, you can use a CR2032 directly without using the normal battery tray.
paniak - Responder
Great help! Accurate, easy to follow directions
Jack Applegate - Responder
Excellent. Just what I needed, to bring life back to the dead.
pvlewisnz - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 31
Últimos 30 dias: 147
Ao todo: 15,621
