Ir para o conteúdo principal
Cabinet Door Butt Hinge Replacement
Laura Carew
Laura Carew e 2 outros colaboradores
Última atualização em December 22, 2023
10 minutos
Fácil
When your cabinet is hanging on just one hinge, the door is unable to close all the way. This can damage the wood on the cabinet and the hinge itself. With this quick and easy guide to replace a broken hinge, you can save your cabinet door.
Unlike other hinge replacement guides on iFixit, we're focusing on replacing a butt hinge, which is better for holding heavier items than others. It is for this reason that it's so important to replace any broken butt hinge—the possibility of damaging your heavy cabinet door is more likely.
O que você precisa
Peças
Ferramentas
  1. Cabinet Door Butt Hinge Replacement, Cabinet Door Butt Hinge: passo 1, imagem 1 %32
    • Determine where the cabinet needs repair: on the top or bottom hinge.
  2. Cabinet Door Butt Hinge Replacement: passo 2, imagem 1 %32
    • Measure the hinge to make sure you have the correct size of your butt hinge.
    • Measure the distance between the screws and the height and width of the hinge to get the correct hinge.
  3. Cabinet Door Butt Hinge Replacement: passo 3, imagem 1 %32
    • Remove the screws from the door with a Phillips #00 screwdriver and remove the hinge.
    • Keep the screws nearby; you will need them later.
  4. Cabinet Door Butt Hinge Replacement: passo 4, imagem 1 %32
    • Align the cabinet door to stand straight with any surrounding cabinets.
  5. Cabinet Door Butt Hinge Replacement: passo 5, imagem 1 %32
    • Place the new hinge where the previous one was. Align the holes together.
  6. Cabinet Door Butt Hinge Replacement: passo 6, imagem 1 %32
    • Tighten the hinge into place using the same screws with your Phillips #00 screwdriver.
Conclusão
If the door closes parallel to any surrounding cabinets, your fix is complete!
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 23
Últimos 30 dias: 57
Duração total: 623
