Brother CS-80 Tire Ring Replacement
Introdução
Vá para o passo 1Use this guide to replace a worn out tire ring for the bobbin winder of a Brother CS-80 sewing machine.
Over time and with constant usage, the bobbin winder tire ring in a Brother CS-80 sewing machine can wear out, break, or even disintegrate. You may need to replace your tire ring if your machine has issues with winding the bobbin correctly.
O que você precisa
Peças
Ferramentas
Exibir mais…
To reassemble your sewing machine, follow the disassembly instructions in reverse order.
