Ir para o conteúdo principal
Bowers and Wilkins T7 Access Panel Replacement
Shane R. Cowper
Shane R. Cowper e 4 outros colaboradores
Última atualização em February 21, 2025
15 minutos
Moderada
Use this guide to learn how to take off or replace your access panel for the Bowers and Wilkins T7 speaker, enabling you to replace every other part.
O que você precisa
Ferramentas
Exibir mais…
  1. Bowers and Wilkins T7 Access Panel Replacement, Access Panel: passo 1, imagem 1 %32
    • As with all electronic devices, make sure your device is powered off before you begin.
    • Gently lift up the access panel; it should easily "pop" open.
  2. Bowers and Wilkins T7 Access Panel Replacement: passo 2, imagem 1 %32
    • Remove 14mm screws on the front panel with a J1 Phillips head screwdriver.
    • There are 8 screws in total.
  3. Bowers and Wilkins T7 Access Panel Replacement: passo 3, imagem 1 %32 Bowers and Wilkins T7 Access Panel Replacement: passo 3, imagem 2 %32
    • Be gentle, the rubber seal is fragile and easy to tear, resulting in cosmetic damage to your device.
    • Using the ifixit Opening Tool, carefully pry off the rubber seal around the sides.
    • The seal is held by adhesive, if this is proving difficult you can use a heat gun to help the process.
  4. Bowers and Wilkins T7 Access Panel Replacement: passo 4, imagem 1 %32 Bowers and Wilkins T7 Access Panel Replacement: passo 4, imagem 2 %32
    • The cover is the most difficult part to remove. As you work, pry continuously, moving the tool around the device, working it a little further as you go.
    • Using the ifixit Opening Tool, pry open at the seam found under the rubber seal.
    • As the cover starts to come off, you can lift up using your hand.
  5. Bowers and Wilkins T7 Access Panel Replacement: passo 5, imagem 1 %32 Bowers and Wilkins T7 Access Panel Replacement: passo 5, imagem 2 %32 Bowers and Wilkins T7 Access Panel Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Gently squeeze the internal locking mechanism inside the red and white terminals with either your fingers or a pair of precision tweezers.
    • While squeezing the internal locking mechanism, pull back the terminal.
    • Repeat this process for the second speaker.
Conclusão
Shane R. Cowper
Membro desde: 03/02/17
131 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S7-G1, Cagle Spring 2017 Membro de USF Tampa, Team S7-G1, Cagle Spring 2017
USFT-CAGLE-S17S7G1
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 10
Últimos 30 dias: 26
Duração total: 2,985
