Ir para o conteúdo principal
Bosch Dishwasher SPS60M08AU 12019637 water heater pump leak Replacement
Ralph Loveday
Ralph Loveday e 2 outros colaboradores
Última atualização em August 1, 2024
Nenhuma estimativa
Moderada
Guia colaborativo
Our 3 year old Bosch dishwasher developed a leak into the bottom tray. While filling with water, the "Check Water" indicator would light and the dishwasher would not run. As it was out of warranty, I decided to see if the leak was easily fixed.
NOTE: there is a 4.5kg weight in a black plastic case mounted at the rear of the plastic tray.
  1. Bosch Dishwasher SPS60M08AU 12019637 water heater pump leak Replacement, Check for leak: passo 1, imagem 1 %32
    • Check for leak by holding palm over inlet and blowing into outlet (right). If you can hear an air leak fill the cavity (arrow) with a good caulk or silicone.
Conclusão
Uma outra pessoa concluiu este guia.
Ralph Loveday
Membro desde: 02/10/23
97 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 96
