Boosted Board 1st Generation Skateboard Bearings Replacement
Introdução
Ir para o passo 1Good bearings are essential for smooth ride. This guide will help you take out and replace the skateboard bearings on the rear or front wheels of your Boosted Board. You can choose to replace the bearings with new ones, or just clean the existing bearings.
O que você precisa
Ferramentas
Loosen the two 16.74 mm motor mount hex nut screws with a 9/64" Allen wrench.
To reassemble your device, follow these directions in reverse order.
Uma outra pessoa concluiu este guia.
Gear Up For Future Repairs
Shop all
