Blu Studio Selfie Front Facing Camera Replacement
Introdução
Vá para o passo 1Use this guide to replace the front facing camera of the Blu Studio Selfie.
O que você precisa
Turn the front of the phone away from you.
Run your fingers along the sides of the phone to identify where the case can be pulled apart.
Identify the crevice at the bottom of the battery.
Gently lift the battery free of the phone.
Ferramenta utilizada neste passo:Tweezers$4.99
Use tweezers to lift the black tab on the ZIF connector and pull the ribbon cable out of place.
Using a pair of tweezers for assistance, remove the front facing camera from its case.
3 outras pessoas executaram este guia.
