Ir para o conteúdo principal
Blu G90 Pro Battery, Power/USB board Replacement
Derek Clayton
Derek Clayton e um outro colaborador
Última atualização em August 6, 2024
1 hora
Difícil
Guia colaborativo
Battery, Power/USB board, and back cover replacement guide. I made this because none seemed to exist for this model and my charging port/USB stopped working. Quick note, the G90 Pro was not designed to run on only the power port (or be powered by usb only), the circuit pulls from the battery. I replaced both in this guide since I was in the neighborhood.
O que você precisa
Ferramentas
Exibir mais…
  1. Blu G90 Pro Battery, Power/USB board Replacement, Remove back cover: passo 1, imagem 1 %32 Blu G90 Pro Battery, Power/USB board Replacement, Remove back cover: passo 1, imagem 2 %32
    • The G90 Pro has a glued-on back cover. I removed this with a razor, a small suction cup, and guitar picks. There is a thin layer of glue that goes around the perimeter.
  2. Blu G90 Pro Battery, Power/USB board Replacement, Remove Screws: passo 2, imagem 1 %32 Blu G90 Pro Battery, Power/USB board Replacement, Remove Screws: passo 2, imagem 2 %32 Blu G90 Pro Battery, Power/USB board Replacement, Remove Screws: passo 2, imagem 3 %32
    • Remove all screws. These screws secure the mid-frame to the housing. The mid frame consists of three black plastic pieces: the first is the mid-frame main piece, it is the largest and goes around the battery, up around like a frame. The second protects the charging port/usb board. The third protects the motherboard above the camera.
  3. Blu G90 Pro Battery, Power/USB board Replacement, Pry Midframe up/out: passo 3, imagem 1 %32 Blu G90 Pro Battery, Power/USB board Replacement, Pry Midframe up/out: passo 3, imagem 2 %32
    • Now we can pry the midframe out. I used a spudger and jammed it in-between the silver front piece and and the black piece next to the battery (don't damage the battery) and lifted it up. Then I created some space and used the spudger and guitar picks around the perimeter until it popped-off.
  4. Blu G90 Pro Battery, Power/USB board Replacement, Disconnect the battery: passo 4, imagem 1 %32 Blu G90 Pro Battery, Power/USB board Replacement, Disconnect the battery: passo 4, imagem 2 %32
    • The battery connection is the right metal tab. The flap directly below the camera goes from the motherboard to the charging board/usb on the bottom. I believe the one on the left goes to the screen. I disconnected them all before moving forward.
  5. Blu G90 Pro Battery, Power/USB board Replacement, Disconnect charging board: passo 5, imagem 1 %32 Blu G90 Pro Battery, Power/USB board Replacement, Disconnect charging board: passo 5, imagem 2 %32
    • I removed both covers, the one on top seems to protect the motherboard/camera area, the one on the bottom protects the charging port/usb. Go ahead and lift up that gold flap and unplug the pigtail connector (under spudger in pic), then gently lift out the board. There's two little bumps for alignment of the board.
  6. Blu G90 Pro Battery, Power/USB board Replacement, Battery Removal: passo 6, imagem 1 %32 Blu G90 Pro Battery, Power/USB board Replacement, Battery Removal: passo 6, imagem 2 %32 Blu G90 Pro Battery, Power/USB board Replacement, Battery Removal: passo 6, imagem 3 %32
    • The battery is glued to a piece of sticky plastic. There are green arrows on the plastic piece, pull those outward to expose the battery. I used a spudger to gently pry the battery out under the bottom center so as not to damage the thin cables that are below that run under the battery on the right/left sides. Pry point is the red arrow.
  7. Blu G90 Pro Battery, Power/USB board Replacement, Replace charging/usb board and battery: passo 7, imagem 1 %32 Blu G90 Pro Battery, Power/USB board Replacement, Replace charging/usb board and battery: passo 7, imagem 2 %32 Blu G90 Pro Battery, Power/USB board Replacement, Replace charging/usb board and battery: passo 7, imagem 3 %32
    • When replacing the board, don't forget to reattach pigtail connection (connection and anchor points indicated in yellow) and the connection of the board to the mainboard (Yellow arrow).
Conclusão
4 outras pessoas executaram este guia.
Derek Clayton
Membro desde: 06/19/24
265 Reputação
Autoria de 1 guia
Um comentário
Can a more detailed explanation possibly more pictures and videos be included?? I took off the cover but there's a gold metal strip that became disconnected when I opened the back and idk where it goes..and now the phone doesn't power on. Please help
Milk - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 46
Duração total: 243
