Ir para o conteúdo principal
Black and Decker IR02V-T Power Cord Replacement
Kevin B
Kevin B e 2 outros colaboradores
Última atualização em October 3, 2023
15 - 25 minutos
Moderada
This guide demonstrates how to replace a Black & Decker IR02V-T flat iron power cord. A guide like this is crucial because any internal damage to your power cord could lead to a short circuit and would ruin the flat iron.
When completing the process ensure the flatiron is unplugged and has completely cooled down.
O que você precisa
Ferramentas
Exibir mais…
  1. Black and Decker IR02V-T Power Cord Replacement, Power Cord: passo 1, imagem 1 %32 Black and Decker IR02V-T Power Cord Replacement, Power Cord: passo 1, imagem 2 %32 Black and Decker IR02V-T Power Cord Replacement, Power Cord: passo 1, imagem 3 %32
    • Remove the two silicone covers which encase the screws.
    • Remove both 1 mm screws using a T5 Torx screwdriver.
    • Pry open the plastic cover starting from the top of the iron.
  2. Black and Decker IR02V-T Power Cord Replacement: passo 2, imagem 1 %32 Black and Decker IR02V-T Power Cord Replacement: passo 2, imagem 2 %32 Black and Decker IR02V-T Power Cord Replacement: passo 2, imagem 3 %32
    • Remove both caps from the end of the wire by using pliers.
    • Unfold the metal in the caps using the pliers to release the exposed wire.
    • Remove the two 1 mm screws holding down the wire using a Phillips #00 screwdriver.
    • Once the wires are exposed separate and fold to opposite sides.
  3. Black and Decker IR02V-T Power Cord Replacement: passo 3, imagem 1 %32 Black and Decker IR02V-T Power Cord Replacement: passo 3, imagem 2 %32 Black and Decker IR02V-T Power Cord Replacement: passo 3, imagem 3 %32
    • Remove the old power cord from the iron completely.
    • Insert the new cord through the plastic cover and hole of the iron as demonstrated in the image.
  4. Black and Decker IR02V-T Power Cord Replacement: passo 4, imagem 1 %32 Black and Decker IR02V-T Power Cord Replacement: passo 4, imagem 2 %32 Black and Decker IR02V-T Power Cord Replacement: passo 4, imagem 3 %32
    • Expose about half an inch of wire by removing the silicone that encases it.
    • Tie the new wire into a knot and connect the wires accordingly.
    • Place the caps over the exposed wire and use pliers to tighten the metal to secure the wire.
  5. Black and Decker IR02V-T Power Cord Replacement: passo 5, imagem 1 %32 Black and Decker IR02V-T Power Cord Replacement: passo 5, imagem 2 %32 Black and Decker IR02V-T Power Cord Replacement: passo 5, imagem 3 %32
    • Once the caps are over the wires add the two 1 mm Phillips screws along with the small base plate which secures the wire.
    • When all wires are secure place the plastic cover and screw back in the 1mm Torx screws.
Linha de Chegada
Kevin B
Membro desde: 11/10/22
146 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 22
Duração total: 1,211
