Bissell Air180 Fan Replacement
Introdução
Vá para o passo 1The fan on the Bissell Air180 is a vital component in air purification. With propellers constantly in motion, it can be easy for something to get stuck or cause this component to malfunction.
O que você precisa
Ferramentas
Squeeze the clip on the back panel of the bottom housing and pull the panel away from the housing, exposing the air filter.
Remove the four 18mm Phillips #1 screws connecting the bottom housing to the rest of the device.
Pry off the top vent, separating it from the fan and motherboard housing.
Flip the motherboard and fan housing upside down to find where to disconnect the fan from the rest of the device.
Remove the two 11 mm screws using a Phillips #1 screwdriver.
Detach the two wires connecting the fan to the motherboard so the fan is now loose inside the housing.
