Ir para o conteúdo principal
Beats Solo 2 Wireless Power Button Replacement
Victor Diuno
Victor Diuno e 4 outros colaboradores
Última atualização em June 26, 2024
20 minutos
Moderada
If you are experiencing difficulty turning on your Beats Solo 2 Wireless, whether it be due to the power button being broken, stuck, or disconnected from components inside, use this guide to replace the power button.
The power button is located on the outside, below the right ear of the headphone. The power button connects to the battery which tells the headphones when to turn off or on. A broken or stuck power button may result in the headphones not turning on when they are supposed to.
Prior to using this guide inspect power button of the Beats Solo 2 Wireless to ensure that it is broken or not working properly.
O que você precisa
Ferramentas
  1. Beats Solo 2 Wireless Power Button Replacement, Power Button: passo 1, imagem 1 %32 Beats Solo 2 Wireless Power Button Replacement, Power Button: passo 1, imagem 2 %32 Beats Solo 2 Wireless Power Button Replacement, Power Button: passo 1, imagem 3 %32
    • Insert an opening pick in the seam between the right outer speaker casing and the speaker housing.
    • Slide the pick around the perimeter of the casing until the casing releases entirely from the speaker housing.
    • If you encounter any resistance, continue to pry along any spots where the seam is still close together.
    • Failure to loosen the seams may result in the piece breaking partially or completely during removal.
  2. Beats Solo 2 Wireless Power Button Replacement: passo 2, imagem 1 %32 Beats Solo 2 Wireless Power Button Replacement: passo 2, imagem 2 %32
    • Remove the right outer casing.
  3. Beats Solo 2 Wireless Power Button Replacement: passo 3, imagem 1 %32 Beats Solo 2 Wireless Power Button Replacement: passo 3, imagem 2 %32 Beats Solo 2 Wireless Power Button Replacement: passo 3, imagem 3 %32
    • Use a Phillips screwdriver to remove the 2.8 mm screw on the outer shell of the headphones.
  4. Beats Solo 2 Wireless Power Button Replacement: passo 4, imagem 1 %32
    • Remove the power button with your hand or a spudger by prying out the end that is still attached.
    • Beware of the sponge piece when putting the power button assembly back together.
Conclusão
Uma outra pessoa concluiu este guia.
Victor Diuno
Membro desde: 04/02/24
145 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 2-1, Harley Spring 2024 Membro de IUPUI, Team 2-1, Harley Spring 2024
IUPUI-HARLEY-S24S2G1
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 22
Últimos 30 dias: 52
Duração total: 321
