Ir para o conteúdo principal
Bassoon Whisper Key Pad Replacement
Sonakshi Bhatia
Sonakshi Bhatia e um outro colaborador
Última atualização em 12 de ago de 2024
10 minutos
Fácil
Introdução
Ir para o passo 1
Replacing the whisper key pad is a common repair you might have to make in your journey as a bassoonist. Holding down the whisper key or having the whisper key locked while inserting the bocal can cause the bocal to catch on the whisper key pad. This can result in either a partial tear or even complete removal of the whisper key pad. Especially as a student, there may not be enough time to send your bassoon to the music repair shop.
Instead, you can use this guide to perform a simple fix that will get you back to playing as soon as possible. Before you begin this procedure, determine if you need to order a new whisper key pad if the old key pad is too damaged to be reused. The size of the key pad will depend on your instrument’s model.
O que você precisa
Ferramentas
  • Spudger
    Spudger
  1. Bassoon Whisper Key Pad Replacement, Key Pad: passo 1, imagem 1 %32 Bassoon Whisper Key Pad Replacement, Key Pad: passo 1, imagem 2 %32
    • Assess the damage to the whisper key. If the bocal is digging into the whisper key pad, gently swivel it away from the whisper key pad.
    • If the whisper key pad is completely missing, skip to step 4.
    • Make sure the area around the key pad is clear before proceeding.
  2. Bassoon Whisper Key Pad Replacement: passo 2, imagem 1 %32 Bassoon Whisper Key Pad Replacement: passo 2, imagem 2 %32 Bassoon Whisper Key Pad Replacement: passo 2, imagem 3 %32
    • Check to make sure the whisper key lock is disengaged. If the whisper key lock is engaged, gently pull back on the tab to release the lock, returning the whisper key to its place.
  3. Bassoon Whisper Key Pad Replacement: passo 3, imagem 1 %32 Bassoon Whisper Key Pad Replacement: passo 3, imagem 2 %32
    • Remove the bocal while making sure to stay clear of the whisper key.
  4. Bassoon Whisper Key Pad Replacement: passo 4, imagem 1 %32
    • Take apart the bassoon and place the wing joint on a flat surface.
    • Make sure the whisper key is facing up.
  5. Bassoon Whisper Key Pad Replacement: passo 5, imagem 1 %32 Bassoon Whisper Key Pad Replacement: passo 5, imagem 2 %32
    • Take a flat screwdriver and remove the old glue from the key.
  6. Bassoon Whisper Key Pad Replacement: passo 6, imagem 1 %32
    • If the key pad is still partially attached to the key, use the screwdriver to gently make space between the key and the key pad. Pour a small amount of super glue into this space.
    • If the whisper key pad has completely come off of the key, place a drop of super glue in the middle of the key. Place a new key pad on top of the glue.
  7. Bassoon Whisper Key Pad Replacement: passo 7, imagem 1 %32 Bassoon Whisper Key Pad Replacement: passo 7, imagem 2 %32
    • Gently press down on the key pad, ensuring that the glue does not spill out from the sides. If the glue does spill, wipe off the excess with a paper towel.
    • At this point, the instrument can be played again, but the key pad will not set until the glue has dried.
Linha de Chegada
Gear Up For Future Repairs
Shop all
Sonakshi Bhatia
Membro desde: 05/29/24
145 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 37
Ao todo: 192
