BRCK v1 Motherboard Replacement
20 minutos
Moderado
Introdução
Ir para o passo 1Using a hex 2.0 driver, you will remove the top cover. using a pair of tweezers, you will then be able to remove and replace the Brck Motherboard.
O que você precisa
Ferramentas
Remove the nut and washer from the RF connector, located where the antenna was connected.
Quase terminado!
Conclusão
