Ir para o conteúdo principal
BLU Energy X Front Facing Camera Replacement
Sishun Wang
Sishun Wang e 3 outros colaboradores
Última atualização em August 18, 2016
8 minutos
Moderada
The front facing camera is located on the front side of the top motherboard. In order to access it, the motherboard just has to be exposed and then gently lifted. Use caution while disconnecting the front camera from the motherboard because it is easily damaged.
O que você precisa
Ferramentas
  • Spudger
    Spudger
  • Phillips #000 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
Exibir mais…
  1. BLU Energy X Front Facing Camera Replacement, Front Facing Camera: passo 1, imagem 1 %32 BLU Energy X Front Facing Camera Replacement, Front Facing Camera: passo 1, imagem 2 %32 BLU Energy X Front Facing Camera Replacement, Front Facing Camera: passo 1, imagem 3 %32
    • Pry open and remove back cover with plastic opening tools.
  2. BLU Energy X Front Facing Camera Replacement: passo 2, imagem 1 %32 BLU Energy X Front Facing Camera Replacement: passo 2, imagem 2 %32
    • Remove the seven 4mm JIS J000 screws from top plate
    • Remove top plate
  3. BLU Energy X Front Facing Camera Replacement: passo 3, imagem 1 %32 BLU Energy X Front Facing Camera Replacement: passo 3, imagem 2 %32 BLU Energy X Front Facing Camera Replacement: passo 3, imagem 3 %32
    • Flip up the black retaining flap on the front-facing camera ZIF connector.
    • Gently lift up the motherboard, and pull the front-facing camera free of the device.
Conclusão
3 outras pessoas executaram este guia.
Sishun Wang
Membro desde: 02/08/16
630 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 12-2, Eyestone Spring 2016 Membro de USF Tampa, Team 12-2, Eyestone Spring 2016
USFT-EYESTONE-S16S12G2
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 326
